Most recent update: 2024-02-05
熱処理を主体としてコーティング・溶射事業を展開。熱処理設備を活用してろう付け・拡散接合の接合技術の確立。主に熱処理・ろう付け・コーティング・溶射の4事業を展開しております。
Coating( Surface treatment / Other surface treatment ) |
Company name |
株式会社 アイ・シイ・エス (Aishiiesu) |
Website URL | https://www.ics-21.com/ |
Street address |
Tochigi Japan
[See map] |
Person in charge | - |
Capital | 220,000,000 JPY | Employees | 150 |
Annual sales | Unregister | EMIDAS Member Number | 98962 |
Large | Medium | Small |
Mass production | Welding / welding | fixing with wax |
Surface treatment | Cleaning | Hydrocarbon cleaning Ultrasonic cleaning |
Surface treatment | Lap polishing | Lap polishing |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Air quenching Vacuum quenching Austempering Solution heat treatment Sub-zero treatment |
Surface treatment | Other surface treatment | Vacuum deposition Other physical vapor deposition methods (PVD) CVD (chemical vapor deposition) Spattering Coating High-speed frame spraying (HVOF) Spraying Ionized plating Frame spraying Arc spray Plasma spray DLC coating |
