PR message
We are a machine building and automation company with a history of 12 years. With a system of modern processing machines, our processing capacity meets the processing standards for Japanese invested companies in Vietnam. We always put quality first. Looking forward to having the opportunity to cooperate with domestic and foreign enterprises.
Precision automatic machinery designing( Designing / Industrial equipment designing ) |
Company name | Viet Competence JSC., | Website URL | https://vcc-group.vn |
Street address |
Hà Nội Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | Lưu Hùng Cường |
Telephone number | +84-+8424-3780-5300 | Fax number | +84-+8424-3780-5301 |
Capital | Employees | 200 | |
Annual sales | EMIDAS Member Number | 95709 | |
Type of manufacturing | Industrial machinery / Machine tools / Jigs and tools | ||
Main 3 products |
Primary clients |
Large | Medium | Small |
Designing | Mold designing | Injection molding die General metal press die 3D modeling (press) 3D modeling (plastic) |
Designing | Product and part designing | Gear designing Model designing Medical equipment designing Measurement/testing device designing |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing Automatic tool designing General-purpose jig designing |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Plant equipment designing Precision automatic machinery designing Industrial machinery designing Energy-saving machinery designing |
Designing | Electrical planning | Electrical machinery and apparatus designing PCB designing Other electronic part designing Eletronic circuit designing Software designing |
Designing | Simulation | 3D modeling Transmission path simulation Thermal analysis |
Designing | Data creation (3D scan) | Data creation (3D scan) |
Material | Steel component distribution | Stainless steel Shaped stainless steel Perforated metal Spring steel Steel (round) bar Cast-iron pipe |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Planer machining Deep hole drilling Profile milling Straightening Iron Stainless steel Aluminum alloy Copper alloy Machining (resin) Broaching Keyway milling Automatic lathe Bench lathe machining Router machining Milling (resin) Lathe machining (resin) Honing Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Boring milling NC facing NC vertical lathe Combined lathe machining Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Air-conditioning equipment manufacturing Chassis manufacturing Angle machining Pipe bending Deburring Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Cutting Laser and turret punch press processing Electron beam machining Corner shearing Metal mask manufacturing Stainless steel Copper/Aluminum Acrylic Precision cutting |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Jig grinding Centerless grinding Thread grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Plasma welding Robot welding Brazing Stud welding Capacitator spot welding Other bonding methods Hot plate welding High-frequency welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending prototype mold |
Die manufacturing | Press die | Manufacturing Part processing 3D modeling Blanking die Forming die Fine blanking die Progressive die Transfer press die Single press die |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining |
Surface treatment | Cleaning | 5-layer fully automatic washing twin Ultrasonic cleaning |
Surface treatment | Coating | Urethane coating Epoxy coating |
Surface treatment | Printing and others | Engraving |
Surface treatment | Lap polishing | Lap polishing |
Surface treatment | Other surface treatment | Arc spray Tool and die coating |
Assembly/Inspection | Assembly | Precision equipment assembly Office equipment assembly Auto parts assembly Construction component assembly Industrial machinery assembly Toy and sundries assembly |
Parts manufacturing | Machinery part | Gear manufacturing Bearing manufacturing Vacuum components manufacturing Crank shaft manufacturing Optical parts manufacturing Shaft and roller manufacturing Measurement devices manufacturing Mechanical parts |
Parts manufacturing | Electrical part | Harness processing Other electrical part manufacturing Power-supply device manufacturing |
Product manufacturing | Production property | Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing Vacuum equipment manufacturing Food industry machinery manufacturing Fluid equipment manufacturing Industrial furnace/Test furnace manufacturing Industrial robot manufacturing Environmental equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
