ND Vietnam.,JSC is proud to be a supplier of components and equipment for supporting industries
PR message
ND Vietnam Industry is proud to be a supplier of components and equipment for supporting industries with high-quality standards:
- PEM fasteners
- Bolts, nuts, screws, screws according to DIN, ASTM, JIS, ISO..
- Industrial accessories such as hinges, door latches, handles
- Precision mechanical processing: according to customer requirements.
Blind Threaded Standoffs (Type BSO/BSOS/BSOA)
- Surface treatment: galvanized
- Genuine or manufactured goods
PEM Self-Clinching Threaded Studs (Type FH/FHS/FHA)
Genuine imported product PEM
➢ Materials: Carbon steel, galvanized steel, SUS
➢ Function: Self-holding thread is used for stamping on steel plate with a minimum thickness of 1mm, used to link 2 joints together quickly and easily when just using a specialized machine to spread pem, add aesthetic appeal to the product.
➢ Application for plate processing industry, manufacturing electrical cabinets, rack cabinets.
Our commitment:
✓ Products have durability, long-term stability, easy disassembly, adjustment
✓ Widely used in machinery and equipment manufacturing industries, construction works, traffic, ..
✓ A team of highly qualified and professional technicians, always ready to advise on all product information.
✓ Competitive price, on-time delivery nationwide.
PEM® self-clinching studs are installed by placing them in properly sized holes in the sheets and squeezing into place with any standard press. The squeezing action embeds the head of the stud into the sheet. The metal displaced by the head flows smoothly and evenly around the ribs and into the annular groove – creating a flushhead assembly and securely locking the stud into the sheet with high torque-out and pushout resistances.
FH (flush-head) studs are available in aluminum, steel, or stainless steel. They are also available unthreaded on special order.
Flush-head in designated minimum sheet thickness or greater.
Type FH is recommended for use in steel or aluminum sheets HRB (Rockwell “B” scale) 80 or less and HB (Hardness Brinell) 150 or less.
Type FHS is recommended for use in steel or aluminum sheets HRB (Rockwell “B” scale) 70 or less and HB (Hardness Brinell) 125 or less.
Type FHA is recommended for use in aluminum sheets HRB (Rockwell “B” scale) 50 or less and HB (Hardness Brinell) 82 or less.
Self-clinching nuts are installed by placing them in properly sized holes in sheets and applying a parallel squeezing force to the head of the nut. The sheet metal surrounding the head cold flows into an undercut thereby making the fastener an integral part of the sheet. A serrated clinching ring prevents the fastener from rotating after installation.
Provide load-bearing threads in thin sheets with high pushout and torque-out resistance.
Type CLA is recommended for use in steel or aluminum sheets HRB (Rockwell "B" scale) 50 or less and HB (Hardness Brinell) 82 or less.
Types CLS / CLSS are recommended for use in steel or aluminum sheets HRB (Rockwell "B" scale) 70 or less and HB (Hardness Brinell) 125 or less.
Types S / SS are recommended for use in steel or aluminum sheets HRB (Rockwell "B" scale) 80 or less and HB (Hardness Brinell) 150 or less.
Type SP is recommended for use in stainless steel sheets HRB (Rockwell "B" scale) 90 or less and HB (Hardness Brinell) 185 or less.
Eg: CLS-M3-2
Thread Size x Pitch: M3 x 0.5
Thread Code: M3
Shank Code:2
A (Shank) Max.:1.38 mm
Rec. Min. Sheet Thickness:1.4 mm
Hole Size in Sheet + 0.08: 4.22 mm
C Max.: 4.2 mm
E ± 0.25: 6.35 mm
T ± 0.25: 1.5 mm
Min. Dist. Hole C/L to Edge: 4.8 mm
For Use in Sheet Hardness: HRB 70 / HB 125 or Less
Thread Specification: Internal, ASME B1.13M, 6H
Fastener Material: 300 Series Stainless Steel
Standard Finish: Passivated and/or tested per ASTM A380
These standoffs are designed for spacing applications where outer sheet surfaces must be flush and closed for smoother sheet appearance.
BSO standoffs are recommended for use in steel or aluminum sheets HRB 80/HB150 or less.
BSOS standoffs are recommended for use in steel or aluminum sheets HRB 70/HB125 or less.
BSOA standoffs are recommended for use in aluminum sheets HRB 50/HB82 or less.
BSO4 standoffs are recommended for use in stainless steel sheets HRB 88/HB183 or less.
Eg: BSO-M3.5-14ZI, Blind Threaded Standoffs
Thread Size x Pitch: M3.5 x 0.6
Thread Code: M3.5
Length Code: 14
Min. Sheet Thickness: 1 mm
Hole Size in Sheet + 0.08: 5.41 mm
C - 0.13: 5.39 mm
F Min.: 6.50 mm
H Nom.: 6.4 mm
L - Length +0.05 –0.13: 14 mm
Min. Dist. Hole C/L to Edge: 6.8 mm
For Use in Sheet Hardness1: HRB 80 / HB 150 or less
Thread Specification: Internal, ANSI/ASME B1.13M, 6H
Fastener Material: Heat-Treated Carbon Steel
Standard Finish: Zinc plated per ASTM B633, SC1 (5µm), Type III, colorless
Materials:
- Handel and turning-disk: zinc die, black
- Dish: PA, black
- Bottom (90o) LH/RH: zinc die, zinc plated
- Grounding clip: stainless steel
- Locking cylinder and snap wedges: PA
DST Swinghandle RS PrC
Advantages:
- Swinghandle Trimline with pull- and- swinghandle for key cylinder,
- 90o closing rotation.
- RH/LH application.
- For cam and 3-point cam
- Tool-less installation.
- The dish is hooked into the lower cutout and snapped into the upper cutout
- On request available with pre-assembled cam/3-point cam.
- Grounding by assembled grounding clip,
- A non-locked handle has a detent in the door-dish.
Material: Zinc alloy
Finish: Powder coated
Color/Appearance: Black
Thread or Hole Type: M5 x 0.8
Mounting Style :Concealed Mount
Head Style:Phillips Recess #2
Compliance Specification: UL FTTA2 / FTTA8 Type 13
Hinge Style: In-line Knuckle Style
Class:96 - Removable Lift-Off Hinges
Southco’s 96 hinges allow doors to be removed quickly, easily and safely without the use of tools. A non lift-off configuration allows for permanent installation, and the hinges are available in multiple styles to satisfy a variety of applications.
Stainless steel, satin chrome and polished chrome provide a stylish finish and enhanced application aesthetic.
The 96 line provides designers with a range of choices for design flexibility in a cost-effective solution.
Allows for quick, easy door removal
Door can also be permanently installed
Bolt/Screw/Nut manufacturing( Parts manufacturing / Bolt/Screw/Nut ) |
Company name | ND VIET NAM INDUSTRY JOINT STOCK COMPANY | Website URL | https://ndvietnam.com.vn/ |
Street address |
Tu Son Bac Ninh Socialist Republic of Vietnam
[See map] |
Person in charge | Hoang Thuy Hang |
Telephone number | +84-988-392-495 | Fax number | +84-988-392-495 |
Capital | 1,300,000 $ | Employees | 20 |
Annual sales | EMIDAS Member Number | 95373 | |
Type of manufacturing | Construction material | ||
Main 3 products |
Primary clients |
Large | Medium | Small |
Mass production | Mechanical processing | NC turning machining |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
Product manufacturing | Environmental equipment manufacturing | Waste water treatment system manufacturing |
