Most recent update: 2021-02-25
NC milling ( Development and production of prototype/Small-scale production / NC machining ) |
Company name | Công ty CP chế tạo và dịch vụ máy công nghiệp M-SEI | Website URL | https://m-sei.com.vn/ |
Street address |
Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | - |
Capital | Unregister | Employees | 9 |
Annual sales | Unregister | EMIDAS Member Number | 95197 |
Large | Medium | Small |
Designing | Product and part designing | Gear designing Medical equipment designing Measurement/testing device designing External design |
Designing | Jig and tool designing | General jig designing Mass production jig designing Automatic tool designing General-purpose jig designing |
Designing | Test | Nondestructive test |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Precision automatic machinery designing Industrial machinery designing Energy-saving machinery designing |
Designing | Electrical planning | Electrical machinery and apparatus designing |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling Tapping Deep hole drilling Gear hobber Thread-cutting Straightening Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Sintered metal Automatic lathe Bench lathe machining Casting Handles microfabrication Handles microfabrication Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining Boring milling NC facing Combined lathe machining Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Pipe bending Hair line machining Bending (servo) Swaging |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Cutting Laser and turret punch press processing Electron beam machining Corner shearing UV laser machining Dry etching (routing) Metal mask manufacturing Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic Other resins Precision cutting Fiber laser processing |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Internal grinding Centerless grinding Gear grinding NC internal grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Seam welding Arc welding Robot welding Brazing Stud welding Submerged arc welding Other bonding methods Impulse welding Hot plate welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Chassis prototype manufacturing Fused Deposition Molding (FDM) Model manufacturing Aluminum die-casting Prototype/Small-lot molding Simplified/Molding prototype mold |
Die manufacturing | Press die | Part processing Die set machining Blanking die Forming die Fine blanking die Multi forming die Single press die 60 - 300 t |
Mass production | Metal press | Bending Forming Fine blanking Multi forming Coining Iron Stainless steel Aluminum Copper Brass Transfer press (80 - 200 t) |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Five-face/axes machining Complex turning machining Gear cutting machining Micro-hole machining Spinning Iron Stainless Aluminum alloy Copper alloy Sintered metal Automatic screw machining Casting Honing machining Fine particle material accepted High precision |
Mass production | Casting | Sand casting Cast-iron Copper alloy Over 500 g and less than 5 kg Aluminum bronze alloy |
Mass production | Grinding processing | NC plane grinding NC cylindrical grinding |
Surface treatment | Plating/Chemical conversion treatment | Chromium (barrel) Nickel (rack) Black chromium (rack) Nickel chromium (rack) Tin-zinc alloy plating (rack) |
Surface treatment | Polishing/Lapping | Tool polishing Blade polishing Buffing Mirror polishing |
Surface treatment | Printing and others | NC engraving Laser engraving |
Surface treatment | Lap polishing | Dual-face lapping and polishing |
Surface treatment | Heat treatment | Quenching Vacuum quenching High frequency quenching Flame quenching Carburized quenching Salt bath soft nitriding (tufftriding) |
Surface treatment | Other surface treatment | Spattering Buffing Sound blast |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Assembly/Inspection | Repair | Precision equipment repair Industrial machinery repair Machine tool repair |
Assembly/Inspection | Side job processing | Manual labor |
Parts manufacturing | Machinery part | Gear manufacturing Bearing manufacturing Shaft and roller manufacturing Measurement devices manufacturing |
Product manufacturing | Production property | Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
Product manufacturing | Medical equipment manufacturing | Inspection and testing devices |
Product manufacturing | Others | Welfare equipment manufacturing Transportation equipment manufacturing |
