Most recent update: 2019-04-02
Company name |
中国深セン三洪精密機械有限会社 (Sannkouseimitsukikaiyuugennkaisha) |
Website URL | |
Street address | Guangdong People's Republic of China | Person in charge | - |
Capital | 1,000,000 RMB | Employees | 152 |
Annual sales | 10,000,000 RMB | EMIDAS Member Number | 93027 |
Type of manufacturing | Jigs and tools / Machine tools / Measuring machinery |
Large | Medium | Small |
Material | Steel component distribution | Heavy plate Stainless steel Stainless steel pipe Other steel plates and straps Flat steel plate Steel (round) bar Drawn steel pipe Steel castings Other steel pipes |
Material | Nonferrous metal distribution | Plate Steel (round) bar |
Material | Plastic material distribution | ABS resin PA (nylon/polyamide) PEI (polyetherimide) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Planer machining Deep hole drilling Gear hobber Thread-cutting Profile milling Spinning Machining/Handles small-scale production (order from 1 piece) Iron High rigid material Keyway milling Automatic lathe Router machining Simultaneous 5-axis machining Milling (resin) Lathe machining (resin) Casting Handles microfabrication Handles microfabrication Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Combined lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Profile grinding Jig boring Jig grinding Cylindrical mirror grinding Internal grinding Centerless grinding Gear grinding NC internal grinding Double-sided grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Aluminum die-casting |
Development and production of prototype/Small-scale production | Casting | cast iron Cast steel Aluminum alloy Copper alloy |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Zinc (barrel) Chromate (general) Copper (rack) Gold/Silver plating Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Electroless nickel (barrel) Electroless copper (rack) Electroless nickel (rack) Trivalent Chromate (barrel plating) Iron Copper Brass Aluminum Plastic Other anti-rust treatments Hard chromium (rack) Degreasing Black oxide finish Colored alumite Hard alumite Hot-dip galvanizing (small-size Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) Nickel (hoop) Electroless nickel (large) Hard chrome (barrel) Hard chrome (large) Hard alumite (large) |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly Construction component assembly Industrial machinery assembly |
Parts manufacturing | Machinery part | Gear manufacturing Vacuum components manufacturing |
Parts manufacturing | Other parts | Model manufacturing |
Product manufacturing | Production property | Machine tool manufacturing Electrical machinery and apparatus manufacturing Optical products manufacturing Food industry machinery manufacturing Chemical industry machinery and equipment manufacturing Environmental equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Marine vessel equipment manufacturing Steel and furnace apparatus manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction machinery manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing Surgical instruments Dental products Inspection and testing devices |
