Squeeze die casting
[Automotive parts, hydraulic valves and hydraulic cylinders, etc.]
◆ Features
• The die cast is slowly filled up from the bottom with molten metal followed by the application of high pressure.
• Excellent casting surfaces, dimensional accuracy, and pressure resistance.
• Heat treatment is possible in house due to extremely few blowholes.
• It offers a fine solidification structure with high mechanical properties.
◆ Unique IWAKI features
• Multiple types of alloys can be cast.
(such as casting materials, die casting materials, and hypereutectic alloys)
• Our die cooling design enables us to perform directional solidification.
• Our heat treatment is performed in-house.
• The volume of gas contained is less than 1.0 cc per 100 g (actual on-site gas reading).
◆ Support for large-size products
We have 250 to 350 ton die casting machines and can support orders for large-size products.
We specialize in making products with a minimal number of blowholes. In order to speculate blowholes, we use an X-ray scanner and perform product analysis to improve the quality of our products.
• Melting and holding furnaces are available to support different material options depending on usage.
• Two types of machines are available depending on usage.
• Our heat treatment features high thermal efficiency, and stable processing is possible in our continuous furnace system.
◆ Main usage
Company name | Iwaki Diecast Co.,Ltd. | EMIDAS Member Number | 88927 |
-Watari-gun Miyagi Japan |
Telephone number | +81-223-37-3322 | Fax number | +81-223-37-3720 |
Employees | 200,000,000 JPY | Annual sales | |
Employees | 313 | Person in charge | Kei Atsumi |
