Shaft and roller manufacturing( Parts manufacturing / Machinery part ) |
Centerless grinding( Mass production / Grinding processing ) |
Fine particle material accepted( Mass production / Mechanical processing ) |
Mirror polishing( Surface treatment / Polishing/Lapping ) |
Automatic screw machining( Mass production / Mechanical processing ) |
High precision( Mass production / Mechanical processing ) |
High strength( Mass production / Mechanical processing ) |
Barrel finishing (rotation)( Surface treatment / Barrel polishing ) |
Barrel finishing (centrifugal)( Surface treatment / Barrel polishing ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Company name | Mizui Seiko Co., Ltd. | Website URL | |
Street address |
Hitachiota City Ibaraki Japan
[See map] |
Person in charge | 井上 雅弘 |
Telephone number | +81-294-82-2241 | Fax number | +81-294-82-2251 |
Capital | 12,000,000 JPY | Employees | 70 |
Annual sales | Unregister | EMIDAS Member Number | 80885 |
Type of manufacturing | Industrial machinery / Electrical component for transportation equipment / Medical equipment | ||
Main 3 products |
PR message
Achieves high-precision machining by combining fine cutting technology of φ0.3 ~ withsubmicron precision polishing and grinding technology
It requires many technologies such as cutting, polishing, grinding, heat treatment, super finishing, and rolling.
We are one of the few manufacturers of needle rollers, rollers, and precision shafts that can be integrated in-house in Japan.
With technological and quality capabilities, we have obtained high reliability by supplying to the core part of multi-industries such as "automobiles, machine tools, semiconductor devices, FA industry"
We provide the optimum solution by the technical ability of needle-shaped roller, cylindrical roller, crowning roller, needle pin manufacturing using our main special steel "SUJ2" and the service ability by the fastest ultra-short delivery time in Japan.
90% of the production is made to order, and it is possible to handle both SUS and non-ferrous materials other than SUJ2.
In addition, we can make one to custom orders in terms of shape, dimensions, and accuracy.
As a service strength, we are able to respond to short delivery times within 30 days even for mass-produced products from a minimum of 3 days for small LOT while being made to order.
In shaft processing, it is possible to finish extremely small products the size of a grain of rice with high precision and high quality, and to assemble with bushes or flanges.
We are committed to "made in Japan" and aim to be a company with high existence value by manufacturing with the soul of "Mizui-ism".
≪Our technology seeds≫
・ Fine cutting
Both coil material and bar material can be processed. Cutting from Φ0.3 to φ10 with NC / cam type
・ Cutting press processing
Processing all carbon steel / SUS materials from small LOT to large LOT without end face polishing (0.03 or less)
・ Rolling
Knurling (straight-pattern / twilled-pattern) / screwing / forging is possible
・ Polishing
Centerless polishing (through / in-feed) can be used with submicron accuracy.
Inner diameter polishing (small diameter inner diameter polishing from 1.5 mm inner diameter) is available
・ Grinding
Combined grinding is possible with both ends grinding / surface grinding (D cut / H cut)
·Heat treatment
Non-oxidizing continuous furnace / sub-zero special treatment
・ Polishing process
Barrel polishing (vibration, rotation, centrifugal, tilting) with super finishing (super finishing board SPF, burnishing)
Mirror surface processing of Rz 0.1 or less is possible
Roughness Ra0.1 Ra0.2 Ra0.3 and can be controlled to specify roughness
Our strengths are forward stress and solution support, which integrates these technologies to assemble production in a one-stop manner with higher accuracy and lower cost.
≪Main products≫
◆ Needle-shaped roller, rod-shaped roller, crowning roller, needle pin manufacturing
◆ Manufacture of extremely small pins, small diameter shafts, precision shafts, and polishing shafts
◆ Knock pin, positioning pin, dowel pin, parallel pin, guide pin
◆ Shaft & Flange ASSY
◆ Design and manufacture of vacuum formed products
≪Handling material≫
SUJ2 (bearing steel), SKH, SKD, SK4, SCM
SUS201,303,304,316,420,440,630, DSR7
Non-magnetic high-strength material (DSH400F, NSSC130)
Heat-resistant steel SU) High hardness material NS-15MN, NAS106 Tungsten, Nickel
≪Major customers≫
40 listed companies, more than 300 unlisted companies
≪Various certifications, qualifications, etc.≫
ISO9001 ISO14001 (2015 version) Operated for more than 10 years since acquisition in 2007
≪Inquiries≫
Mizui Seiko Co., Ltd. 825, Orihashi-cho, Hitachiota City, Ibaraki Prefecture, 311-0506
TEL: 0294-82-2241 FAX: 0294-82-2251
Person in charge: Masahiro Inoue
E-mail: masa.inoue@mizui.co.jp
URL: http://www.mizui.co.jp
Most recent update:2024-06-21
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Rolling Iron Stainless steel Automatic lathe |
Development and production of prototype/Small-scale production | NC machining | NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Blank cutting | Precision cutting |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Centerless grinding Thread grinding |
Mass production | Mechanical processing | NC turning machining Rolling machining Screw cutting machining Micro-hole machining Iron Stainless Nickel alloy Molybdenum alloy Automatic screw machining Air chuck equipment Fine particle material accepted High precision High strength |
Mass production | Plastic | Vacuum molding |
Mass production | Grinding processing | Plane grinding Centerless grinding Rotary grinding Double-sided grinding |
Surface treatment | Cleaning | Ultrasonic cleaning |
Surface treatment | Polishing/Lapping | Buffing Mirror polishing |
Surface treatment | Heat treatment | Annealing Stress relief annealing (SR treatment) Quenching Air quenching Salt bath quenching Vacuum quenching Solution heat treatment Sub-zero treatment Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Assembly/Inspection | Assembly | Precision equipment assembly |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Machinery part | Bearing manufacturing Shaft and roller manufacturing |
