■ High hardness stainless steel positioning pin
High corrosion resistance and strength of SUS303 or higher, HV400 or harder
Non-magnetic material, magnetic permeability of 1.02 or less
Used as a knock pin (for press fitting, insertion) for positioning.
It can also be used in situations where non-magnetism is required for gear shafts.
The tip shape can be selected from taper, spherical surface, flat, and conical.
■ High corrosion resistance pin Heat resistant steel pin
Special materials with excellent corrosion resistance, heat resistance, and strength can be selected according to the intended use.
Heat resistant material of HV400 or harder
SUS630 (solid solution heat treatment / precipitation hardening treatment)
NS15M NM15K HV450 or harder
All outer diameters are centerless polished to micron accuracy.
Can be used as a knock pin, positioning pin, and dowel pin for a wide variety of uses such as medical, marine, beauty, and vacuum.
Company name | Mizui Seiko Co., Ltd. | EMIDAS Member Number | 80885 |
Hitachiota City Ibaraki Japan |
Telephone number | +81-294-82-2241 | Fax number | +81-294-82-2251 |
Employees | 12,000,000 JPY | Annual sales | |
Employees | 70 | Person in charge | 井上 雅弘 |
Type of manufacturing | Industrial machinery / Electrical component for transportation equipment / Medical equipment |
