General metal press die( Designing / Mold designing ) |
Progressive die( Die manufacturing / Press die ) |
Thin wall (Thickness: 0.5 or less)/small-size sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Below 60 t( Die manufacturing / Press die ) |
Jig and tool manufacturing( Development and production of prototype/Small-scale production / Jig manufacturing ) |
Energy-saving machinery designing( Designing / Industrial equipment designing ) |
Company name |
株式会社 岩沼精工 (Iwanumaseikou) |
Website URL | http://www.iwanuma-seiko.jp/ |
Street address |
Miyagi Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 52 |
Annual sales | Unregister | EMIDAS Member Number | 79865 |
Type of manufacturing | Electronic parts / Jigs and tools / Industrial machinery |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) General metal press die |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Designing | Industrial equipment designing | Carrier machine designing Precision automatic machinery designing Energy-saving machinery designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Iron Stainless steel Aluminum alloy Copper alloy Machining (resin) Milling (resin) Handles microfabrication |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Sheet metal protocol manufacturing Bending (hydraulic) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | CO2 laser machining Thin plate (below 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Form grinding Profile grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending Small-size prototype manufacturing Simplified/Molding |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining Bending die Blanking die Fine blanking die Shaving die Progressive die Single press die Below 60 t 60 - 300 t |
Mass production | Metal press | Blanking Press robot (below 80 t) Press robot (80 -200 t) |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Wire machining Micro-hole machining Iron Stainless Aluminum alloy Copper alloy |
Surface treatment | Printing and others | NC engraving |
Surface treatment | Lap polishing | Lap polishing Dual-face lapping and polishing |
Surface treatment | Barrel polishing | Barrel finishing (rotation) Barrel finishing (centrifugal) |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Assembly/Inspection | Repair | Die repair |
Assembly/Inspection | Inspection | Metal press |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
Product manufacturing | Production property | Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing |
