Most recent update: 2024-01-30
Company name |
田口電機工業 株式会社 (Taguchidennkikougyou) |
Website URL | http://www.taguchi-dk.co.jp |
Street address |
Saga Japan
[See map] |
Person in charge | - |
Capital | 30,000,000 JPY | Employees | 75 |
Annual sales | Unregister | EMIDAS Member Number | 79204 |
Type of manufacturing | Jigs and tools / Industrial machinery / Electronic parts |
Large | Medium | Small |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Copper (barrel) Zinc (barrel) Chromate (general) Rhodium Nickel (rack) Tin (rack) Copper (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless copper (rack) Electroless nickel (rack) Electrocasting Chemical conversion coating Tin-zinc alloy plating (rack) Baking (hydrogen embrittling) Trivalent Chromate (barrel plating) Iron Copper Brass Zinc die-cast Aluminum Stainless steel Plastic Other anti-rust treatments Hard chromium (rack) Titanium Magnesium Degreasing Black oxide finish Colored alumite Hard alumite Hot-dip galvanizing (small-size Hot-dip galvanizing (mid-size Hot-dip galvanizing (large-size Dacrotizing Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing Buffing |
Surface treatment | Heat treatment | Normalizing Annealing Quenching Vacuum quenching High frequency quenching Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Spattering Coating Spraying Resin impregnation Teflon coating Shot peening/WPC Buffing Shot blast Sound blast Glass beads blast Etching (surface treatment) Ionized plating Frame spraying Arc spray Plasma spray Dry type lubricant coating Tool and die coating DLC coating |
