Most recent update: 2024-01-10
Company name |
株式会社 アイオー精密 (Aio-seimitsu) |
Website URL | https://www.aio-precision.co.jp/ |
Street address |
Iwate Japan
[See map] |
Person in charge | - |
Capital | 175,340,000 JPY | Employees | 558 |
Annual sales | 7,400,000,000 JPY | EMIDAS Member Number | 5014 |
Type of manufacturing | Machine tools / Industrial machinery / Transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Gear hobber Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Machining (resin) Sintered metal Keyway milling Automatic lathe Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Boring milling NC facing Combined lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Profile grinding Internal grinding Centerless grinding NC internal grinding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Small-size prototype manufacturing |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Black chromium (barrel) Chromate (general) Gold/Silver plating Chromium (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (rack) Chemical conversion coating Aluminum Stainless steel |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing |
Surface treatment | Heat treatment | Normalizing Annealing Full annealing Straightening annealing Quenching Air quenching Vacuum quenching High frequency quenching Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Teflon coating Shot peening/WPC Shot blast Sound blast |
