Most recent update: 2023-03-17
Microfabrication (laser machining )( Development and production of prototype/Small-scale production / Blank cutting ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Thin wall (Thickness: 0.5 or less)/small-size sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 ヤスヨシ (Yasuyoshi) |
Website URL | http://www.yasuyoshi.co.jp/ |
Street address |
Ishikawa Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 40 |
Annual sales | Unregister | EMIDAS Member Number | 33424 |
Type of manufacturing | Electronic parts / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Automatic lathe Simultaneous 5-axis machining Handles microfabrication |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing NC set press Precision sheet metal machining Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) Can manufacturing (over 5 m) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Corner shearing CO2 laser machining Microfabrication (laser machining ) Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Precision cutting |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Stud welding Fiber welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Rubber | Blanking Urethane rubber NBR Packing-related products Press stamping |
Surface treatment | Plating/Chemical conversion treatment | Acid pickling Aldine treatment (aluminum chromate) Stainless steel Hard alumite Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Coating | Air-spray coating Powder coating Urethane coating Lacquer coating Epoxy coating |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing Mirror polishing |
Surface treatment | Other surface treatment | Buffing |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Spring | Thin leaf spring Stainless steel |
