Most recent update: 2024-05-08
トータルコストダウンを行える各種材料・部品の販売と、取引のトラブル解決や資材調達の代行、ご支援とご提案により製造業のお力になりたいと考えております。
Screw manufacturing( Parts manufacturing / Bolt/Screw/Nut ) |
Company name |
ジェイマット 合同会社 (Jeimatto) |
Website URL | https://j-mat.net/ |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 5,000,000 JPY | Employees | 1 |
Annual sales | Unregister | EMIDAS Member Number | 102452 |
Type of manufacturing | Industrial machinery / Electronic parts / Transportation equipment |
Large | Medium | Small |
Material | Steel component distribution | Stainless steel Steel (round) bar Wires |
Material | Nonferrous metal distribution | Steel (round) bar Titanium Nickel |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Rolling Thread-cutting Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Nickel alloy Molybdenum alloy Shaper machining Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining Combined lathe machining Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Air-conditioning equipment manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Coating Hair line machining Bending (hydraulic) Bending (servo) |
Development and production of prototype/Small-scale production | Prototype processing | Punching Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Mechanical processing | Machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Wire machining Gear cutting machining Rolling machining Screw cutting machining Iron Stainless Cemented carbide Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Automatic screw machining Honing machining Titanium Fine particle material accepted Ultra-thin High precision |
Mass production | Forging | Header machining Hot forging Cold forging Upsetter forging Iron 500 g - 5 kg Over 5 kg Free forging |
Mass production | Sheet-metal processing | Can-making Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Painting process Hairline processing |
Parts manufacturing | Machinery part | Mechanical parts |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Nut manufacturing Screw manufacturing |
