Most recent update: 2024-03-25
Thickness: 0.2 mm - 3.2mm( Mass production / Metal press ) |
Company name |
新興電機 株式会社 (Shinnkoudennki) |
Website URL | https://www.shinkou-dk.co.jp/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 50 |
Annual sales | Unregister | EMIDAS Member Number | 99518 |
Type of manufacturing | Audio-video equipment / Telecommunication equipment / Electrical component for transportation equipment |
Large | Medium | Small |
Designing | Test | Destructive test |
Development and production of prototype/Small-scale production | Machining | Tapping Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Honing Brass |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Deburring Coating Thin wall (Thickness |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding Brazing Projection welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Jig and tool manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Drawing die Bending die Blanking die Shaving die Progressive die Single press die Below 60 t 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Shaving Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness general purpose precision Degreasing welding Tap processing crimp Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Mechanical processing | Tapping machining Rolling machining Iron Stainless Copper alloy |
Mass production | Sheet-metal processing | Precision sheet metal processing Sheet metal prototype manufacturing Deburring process Painting process Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Welding / welding | Projection welding Spot welding fixing with wax Stud welding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Electroless copper (barrel) Nickel (rack) Tin (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Electroless copper (rack) Trivalent Chromate (barrel plating) Iron Copper Brass Aluminum Stainless steel Hard chromium (rack) Degreasing Black oxide finish Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Cleaning | Ultrasonic cleaning |
Surface treatment | Coating | Air-spray coating Powder coating Electrodeposition coating Melamine coating Urethane coating Acrylic coating Epoxy coating |
Surface treatment | Polishing/Lapping | Buffing |
Surface treatment | Printing and others | Silk screen printing |
Surface treatment | Heat treatment | Annealing Carburized quenching |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Assembly/Inspection | Repair | Die repair |
Assembly/Inspection | Inspection | Metal press |
Assembly/Inspection | Side job processing | Manual labor |
