Most recent update: 2023-07-28
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 阪ノ上製作所 (Sakanoueseisakusho) |
Website URL | |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 16 |
Annual sales | Unregister | EMIDAS Member Number | 99245 |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Tapping Thread-cutting Iron Stainless steel Aluminum alloy Copper alloy |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Precision sheet metal machining Sheet metal protocol manufacturing Deburring Coating Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Laser and turret punch press processing Corner shearing CO2 laser machining Laser marking Thin plate (below 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding |
Development and production of prototype/Small-scale production | Prototype processing | Bending Small-size prototype manufacturing prototype mold |
Mass production | Sheet-metal processing | NC set press Precision sheet metal processing Deburring process Painting process Bender processing (flood control) Bender processing (servo) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Blank cutting | Laser marking Turret punch punching Shirring Laser and turret punch punching Connor Shah CO2 laser processing Thin plate 6 mm or less stainless |
Mass production | Welding / welding | Spot welding |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Nickel (rack) Alumite (anode oxidation) Aldine treatment (aluminum chromate) Trivalent Chromate (barrel plating) Iron Aluminum Stainless steel Colored alumite Unichromate (white) |
