Business support service
Skyberry
Skyberry is a mobile Wi-Fi equipped with a cloud SIM that allows you to use local lines all over the world.
Since the monthly fee is set at a reasonable price just for use in Thailand,
this is a must-have item for those who may go abroad even once a year!
[Do you have any problems with means of communication in abroad? ]
・ Roaming data communication is slower and less stable than the local line.
・ If you replace the SIM card with your usual device, you will miss an important call to your number.
・ Top-up is troublesome when the balance is used up
・ There is a long line at the airport counter and it takes time to purchase to buy local sim card.
・ It's okay if you are always in a hotel or cafe but you cannot communicate when you are on the move,
and then you end up having no internet data outside in abroad.
・ Since you share a network with unknown strangers, there are many security problems.
Skyberry can solve these problems.
[Advantages of Skyberry]
1. Data communication charge in borderless target countries is as same as data communication charge in Thailand
No matter where you use it in 90 countries covered by the flat rate, you can use it with the same flat data communication charge as you use in Thailand.
No complicated procedures are required for overseas use. You can seamlessly take out the Wi-Fi environment from your home to overseas.
2. Achieve a comfortable internet life with 4G LTE support in each country
It is faster and more comfortable than roaming because it applies the local SIM of each country remotely instead of roaming.
There is no speed limit, and you can access to the internet with stress-free high-speed communication in 4G LTE compatible areas.
3. Perfect security
Since public wireless LANs such as hotels and cafes are shared types, they may be targeted by malicious people.
Skyberry's communication is one-to-one communication using a mobile communication network, and it is your own personal HotSpot so that you can rest assured.
4. Supports short-term to long-term rental
It can be rented for several days, and there is also a long-term rental with a monthly contract.
Skyberry can provide a Wi-Fi environment that can be connected at any time from domestic business trips in Thailand to overseas business trips and temporary return to Japan.
After this pandemic is over, I think there will be more business trips and travels abroad.
Please take advantage of Skyberry.
Click here for details
https://th.skyberry.me/
Company name | BerryMobile Co., Ltd. | EMIDAS Member Number | 98732 |
Country | Kingdom of Thailand | Street address |
Bangkok Bangkok Kingdom of Thailand |
Telephone number | +66-2-105-4568 | Fax number | +66-2-105-4568 |
Employees | Annual sales | ||
Employees | 39 | Person in charge | Hitomi Sano / Mr.Nathapon (TH/EN) |
Type of manufacturing | Telecommunication equipment | ||
