Most recent update: 2023-03-21
弊社は機械部品加工をメインで、治具、自動化設備、自動車関連などの部品を製造します。製品の素材から、機械加工、熱処理、表面処理まで一貫した製造サービスを提供致します。
Machining( Mass production / Mechanical processing ) |
Company name |
大連市潤森精密機械加工有限会社 (Dairennshijunnshinnseimitsukikaikakouyuugenngaisha) |
Website URL | http://ja.rs-precisionparts.com/ |
Street address |
Liaoning People's Republic of China
[See map] |
Person in charge | - |
Capital | 2,000,000 JPY | Employees | 9 |
Annual sales | 10,000,000 JPY | EMIDAS Member Number | 98727 |
Type of manufacturing | Jigs and tools / Machine tools / Industrial machinery |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Deep hole drilling Gear hobber Thread-cutting Machining/Handles small-scale production (order from 1 piece) Keyway milling |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Five-face machining NC facing NC vertical lathe Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Cylindrical grinding Double-sided grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Arc welding Brazing Stud welding Projection welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Jig and tool manufacturing |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Complex turning machining Wire machining Micro-hole machining Electrical discharge machining |
Mass production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Internal grinding NC internal grinding Double-sided grinding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Electroless nickel (barrel) Electroless nickel (rack) Hard chromium (rack) Degreasing Black oxide finish Colored alumite Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) Nickel (hoop) Black nickel Hard chrome (barrel) Hard alumite (large) |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Salt bath quenching Vacuum quenching High frequency quenching Flame quenching Sub-zero treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
