1. The structure of chain conveyor includes
- Frame material: Stainless steel, aluminum profile...
- Chain material: Plastic POM, brown color, shaft is made of stainless steel
- Conveyor roller: According to the plastic chain loader
- Tonnage of roller conveyor: less than 50kg/m
- Electrical system: Motor, speed control inverter, control cabinet, sensor auxiliary equipment, hmi, plc..
- Size: From 500m to 50,000mm long, from 50mm to 1500mm wide.
- Power supply using 1 phase 220V or 3 phases 380V
- Gear reduction motor: It is a type of geared motor with a capacity of 0.2, 0.4, 0.75, 1.5, and 2.2KW.
- Length and width: depending on customer needs.
- Working environment: from -10 - 90°C.
2. Outstanding features of plastic chain conveyor
- Light conveyor weight helps save energy use
- No slipping when pulling the load
- Easy to disassemble and move.
- Used in food canning lines
- Has a simple mechanical structure, easy to install and maintain.
3. Application of plastic chain conveyor
- Plastic chain conveyors are used in the food industry, confectionery, beverage and agricultural product processing such as pepper and cashew; In
aquatic products such as shrimp and fish processing lines...
- Helps increase productivity in the production process, easy to control quality
- High performance and reliability in transmission
- Use to replace human transportation, automate machine lines
Company name | INTECH GROUP.,JSC | EMIDAS Member Number | 96609 |
Country | Socialist Republic of Vietnam | Street address |
Hoai Duc Ha Noi Socialist Republic of Vietnam |
Telephone number | +84-966966103 | Fax number | +84-243-7653-875 |
Employees | 5,200,000 $ | Annual sales | 10,000,000 $ |
Employees | 260 | Person in charge | Intech Group |
Type of manufacturing | Jigs and tools / Industrial machinery / Transportation equipment | ||
Primary clients |
