PR message
Our main products including distribution cabinet lock, distribution panel lock, coin lock, hinges, pulls, copper bars, fasteners, bolts, screws, earth terminals and so on.
Lock manufacturing( Parts manufacturing / Other parts ) |
Company name | HOSHIMOTO VIETNAM CO.,LTD. | Website URL | https://hoshimoto.vn/ |
Street address |
Nam Tu Liem Dist. Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | Hoshimoto |
Telephone number | +84-243-244-4901 | Fax number | +84-24-3244-4902 |
Capital | Employees | 5 | |
Annual sales | Unregister | EMIDAS Member Number | 95836 |
Type of manufacturing | Heavy electric machinery / Machine tools / Industrial machinery | ||
Main 3 products |
Large | Medium | Small |
Designing | Mold designing | Casting die designing |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Designing | Simulation | Casting |
Designing | Data creation (3D scan) | 3D printer |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Profile milling Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Nickel alloy Automatic lathe Bench lathe machining Simultaneous 5-axis machining Casting pipe manufacturing Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Boring milling NC vertical lathe Combined lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Deburring Mirror surface machining Hair line machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Cutting CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Thread grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Casting | die-cast Lost wax Low pressure casting Metal injection molding (MIM) Zinc alloy 500g or less |
Die manufacturing | Casting die | Designing Manufacturing Die-casting part processing NC data creation 3D modeling Die-casting die Lost-wax casting die |
Mass production | Metal press | Drawing Bending Blanking Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Transfer press (80 - 200 t) plating Tap processing crimp Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Wire machining Rolling machining Screw cutting machining Electrical discharge machining Iron Stainless Cemented carbide Aluminum alloy Copper alloy Automatic screw machining Honing machining |
Mass production | Die-casting | 125 t or less 125 - 250 t Zinc |
Mass production | Forging | Header machining Cold forging Iron Others Below 500 g |
Mass production | Casting | Lost-wax Low-pressure casting Cast steel Zinc alloy 500 g and below Over 500 g and less than 5 kg Metal injection molding (MIM) |
Mass production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Centerless grinding Thread grinding NC internal grinding |
Mass production | Sheet-metal processing | Pipe processing NC set press Housing manufacturing Sheet metal prototype manufacturing Pipe bender processing Deburring process Mirror surface material processing Hairline processing Bender processing (flood control) Bending process |
Mass production | Blank cutting | Turret punch punching Cutting process Connor Shah Thick plate 6 mm or more stainless Copper / aluminum Precision cutting |
Mass production | Welding / welding | CO2 welding Spot welding TIG welding (argon welding) fixing with wax Stud welding |
Surface treatment | Plating/Chemical conversion treatment | Tin (barrel) Chromium (barrel) Zinc (barrel) Tin (rack) Copper (rack) Chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Parkerizing (phosphate film) Tin-zinc alloy plating (rack) Baking (hydrogen embrittling) Trivalent Chromate (barrel plating) Iron Copper Brass Zinc die-cast Aluminum Stainless steel Hard chromium (rack) Degreasing Hot-dip galvanizing (large-size Unichromate (white) Colored chromate (multi-color) |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Electrodeposition coating UV resistant coating Acrylic coating |
Surface treatment | Polishing/Lapping | Electropolishing Buffing Mirror polishing |
Surface treatment | Heat treatment | Normalizing Annealing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Sound blast |
Parts manufacturing | Machinery part | Connection parts manufacturing Mechanical parts |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
Parts manufacturing | Spring | Leaf spring Conical spring Stainless steel |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing |
Parts manufacturing | Other parts | Lock manufacturing |
