Machine tool
KANA
The Heart of All Machinery, Smoothly Transmitting Power
The roller chain is a crucial component used for power transmission in various applications including industrial machinery, agricultural equipment, and bicycles. Despite its simple structure, it combines high durability with efficient power transmission capabilities, enhancing machinery performance to its fullest. This article will elaborate on its features and specifications in detail.
Features
The primary features of the roller chain include its durability and high transmission efficiency. The precisely manufactured pins and rollers allow for smooth movement between links, minimizing power loss. Furthermore, proper maintenance can prolong its performance over time. It can also perform well under diverse environmental conditions, making it suitable for use in areas with significant humidity or temperature fluctuations.
Specifications
Roller chains are offered in various sizes and materials depending on their application. Generally, the pitch (the distance between pins) is selected based on the distance that power needs to be transmitted and the size of the machinery. Regarding materials, stainless steel or nickel alloy may be used for applications requiring corrosion or heat resistance. Additionally, alloy steel might be chosen for applications needing increased strength.
For more information, please download the PDF or feel free to contact us.
Company name | KATAYAMA CHAIN (THAILAND) CO., LTD. | EMIDAS Member Number | 95545 |
Country | Kingdom of Thailand | Street address |
MOO 10 KHAOSONG, SRIRACHA Chonburi Kingdom of Thailand |
Telephone number | 03-300-2043 | Fax number | 03-300-2043 |
Employees | 4,000,000 THB | Annual sales | |
Employees | 10 | Person in charge | Mr. Shikata |
