PR message
Our Thai factory is the main manufacturing base of the Sodick Group which provides electric discharge machines and technologies for advanced processing applications.
Machine tool 3-axis linear motor drive High-speed
high-precision electrode processing machine Sodick Thailand TS-50L
Each axis stroke X × Y × Z (mm) 500 x 400 x 300
Spindle rotation speed (min-1) 18000
Machine body dimensions Width x Depth x Height (mm) 1885 x 2615 x 2704
Machine body mass (kg) 4700
Achieve higher speed, higher precision, and higher quality machining with AI
(artificial intelligence).
Precision die-sinking electric discharge machine that supports precision mold machining and precision parts machining.
The machine is equipped with a precision correction function that realizes a 50% reduction in thermal displacement as standard equipment.
A high-output linear motor developed and manufactured in-house, it realizes high-speed and high-response machining. In addition, a high-rigidity mechanical structure optimally designed using the latest CAE analysis technology has been realized, and the precision correction function "TH COM" has been adopted to achieve a thermal displacement amount of 1/2 compared to conventional machines.
Significantly improved machining speed, machining accuracy, and machining surface quality in all areas.
We have adopted a newly developed "SP power supply" for die-sinking electric discharge machines. "TMM4" circuit installed as standard in "SP power supply": Roughing speed improvement, "TPC4" circuit: Intermediate finishing processing speed improvement, "BSN4" circuit: Surface quality in finishing processing, processing speed improvement combined, high speed Achieves precision machining.
Suppression of electrode wear and flexible control of various machined surface
qualities.
The latest discharge control technology "Arcless 4" circuit, the performance of the die-sinking electric discharge machine is dramatically improved, such as further speeding up, suppression of electrode wear to the utmost limit, and realization of various machined surface qualities from satin finish to mirror surface. In addition, the machining assist function (AI condition advisor) "LN Pro AI" is installed as standard.
Based on high-precision and stable molding by V-LINE®, we have developed an electrification-compatible "eV-LINE" and a new mold clamping mechanism to improve productivity and save energy by increasing the cycle.
Electrification of V-LINE®
The V-LINE® injection and plasticization device, which is highly accurate and highly reproducible, has been driven by a servo motor. The measurement value and the position information of the injection position are controlled in a closed loop to improve the accuracy of each position and realize a high degree of repeatability of plasticization, measurement and injection. For injection devices with plunger diameters of φ28 mm and φ40 mm, speed-oriented units and pressure-oriented units are available, and the unit suitable for the molded product can be selected.
Electrification of mold clamping operation
By adopting a mold clamping device driven by a servo motor and a unique toggle link mechanism, it is possible to shorten the mold opening / closing cycle. The movable platen is supported by a linear guide arranged with a long span to stabilize the mold posture.
In addition, the electrification of these devices has realized a significant reduction in power consumption and improved the quietness of operating noise.
Operation panel with an emphasis on intuition
We have newly developed an operation panel that uses a selector switch exclusively for the "MS100". More intuitive operability is realized, such as operating the switch in the direction in which you want to move each unit, and molding can be performed with simple operations.
The "AL600G i Groove+ Edition" is the latest wire EDM machine from Sodick, designed to reduce power consumption and improve machining efficiency. By incorporating inverter control technology for all pump units, it optimizes power usage based on machining status. This results in up to 50% reduction in annual energy consumption (for 60Hz areas) and 20% increase in the number of machined parts per year, compared to the 2016 model.
■ Key Features
- Up to 50% energy savings (for 60Hz areas)
- 20% increase in machining productivity (more parts machined per year)
- Inverter-controlled energy optimization for each machining operation
- High-precision machining with Sodick’s linear motor drive technology
- Eco-friendly design to reduce environmental impact
■ Specifications
- Machining Method: Wire Electrical Discharge Machining (Wire EDM)
- Drive System: Linear Motor Drive
- Workpiece Size: Thickness 40mm, Circumference 40mm (Standard test conditions)
- Wire Diameter: φ0.2mm
- Energy Reduction Rate: Up to 50% (for 60Hz areas), 30% (for 50Hz areas)
- Machining Productivity Improvement: Annual machined workpieces increased from 4,300 to 5,300 (Standard test conditions)
■ Applications
- High-precision mold manufacturing: Ideal for precision cutting in mold production
- Aerospace component machining: Reduces energy consumption in aerospace manufacturing
- Medical device manufacturing: Supports precision cutting for medical equipment production
- Electronic component manufacturing: Suitable for high-precision, efficient micro-machining
This machine helps manufacturers reduce production costs while enhancing machining efficiency. Additionally, it supports sustainable and environmentally friendly production practices.
■ Download the PDF or contact us for more details.
Company name | Sodick (Thailand) Co., Ltd. | Website URL | https://www.sodick.co.th/ |
Street address |
Klongneung, Klongluang, Pathumthani Pathum Thani Kingdom of Thailand
[See map] |
Person in charge | Pachara |
Telephone number | +66-2-529-2450-6 | Fax number | +66-2-529-2459 |
Capital | Employees | Unregister | |
Annual sales | Unregister | EMIDAS Member Number | 95486 |
Main 3 products |
