PR message
DULICO is proud to be a pioneer in the field of copper sheet rolling and casting, as well as high-quality metal detail machining. DULICO is committed to delivering superior products that meet the highest standards of quality and excellence.
Dulico is a leading company in Viet Nam, which manufacturing brass strip and copper alloy strip with continuous casting technology that can produce 10000 tons per year.
Brass strip is used in several areas such as civil electric and industrial electric, lock industry, in and exterior decoration design., etc.
Factory standard: ISO 9001, JIS H 3100, ISO 14001, ISO 45001
Dulico has more than 30 years of experiences in manufacturing of brass blank keys. Dulico is also the manufacturers of the brass strip, which is input materials for blank keys, so our blank keys are very cost competitive and has high quality.
Blank key ‘s type: Brass blank key, Brass blank key Niken plated, Brass blank key Niken plated with keyway.
Molding: Dulico designs and create the molds by ourself.
Materials: Brass strip or sheet C2801, C2680.
Dulico produces various type of brass fittings using forging and CNC machining based on brass and copper materials.
Making from scrap to end products, Dulico can stricly controll the quality and cost of brass fittings.
Dulico produces OEM/ODM stamping parts using self-designed simple or progesive molds to create precise parts based on various materials like steel, SUS, brass or copper. Our long eperiences in stamping technology and professional management will meet your strict requirement.
Molding:
Dulico design & creates the single or progessive mold by ourself
Management
5S, Kaizen, TPM, ISO 9001:2015
DULICO provides high-quality manufacturing services for electrical fittings, meeting the diverse needs of the electrical and electronics industries. By applying strict production and quality control processes, from material selection, machining to product finishing, we ensure maximum durability, stability, and performance for our fittings
Dulico is specializing in manufacturing door hinges based on SUS 201, SUS 304 or steel. With more than 30 years of experience in this field, we have worked with several companies in Vietnam and overseas such as: Viet Tiep Lock Join Stock Company, Minh Khai Lock Company, Yamaha, etc… We have high confidence to meet the strict request and demand of customer.
Stainless steel hinges SUS 201, SUS 304
Steel hinges electro plated
Management system
Turret punch press processing( Development and production of prototype/Small-scale production / Blank cutting ) |
Company name | DULICO MANUFACTURING AND TRADING COMPANY LIMITED | Website URL | https://dulico.vn/ |
Street address |
Nam Tu Liem Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | David Tung |
Telephone number | +84-975441115 | Fax number | +84-2437805037 |
Capital | 10,000,000 $ | Employees | 150 |
Annual sales | 50,000,000 $ | EMIDAS Member Number | 95475 |
Type of manufacturing | Jigs and tools / Home electrical appliances / Electrical component for transportation equipment | ||
Main 3 products |
Primary clients |
Large | Medium | Small |
Designing | Mold designing | Forging die designing Casting die designing Progressive die designing (auto) Drawing metal press die designing Transfer press die designing General metal press die Extrusion molding die designing 3D modeling (press) NC data creation (press) |
Designing | Jig and tool designing | General jig designing Mass production jig designing Automatic tool designing General-purpose jig designing |
Designing | Test | Nondestructive test Investigative research |
Designing | Industrial equipment designing | Precision automatic machinery designing Energy-saving machinery designing |
Designing | Simulation | Casting |
Material | Specialized material distribution | Phosphor bronze |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose lathe machining Planer machining Deep hole drilling Thread-cutting Profile milling Straightening Iron Stainless steel Copper alloy Broaching Keyway milling Automatic lathe Bench lathe machining Shaper machining Router machining Air chuck equipment Casting Brass |
Development and production of prototype/Small-scale production | NC machining | NC milling NC lathe machining NC facing NC vertical lathe |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Swaging |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Thin plate (below 6 mm) Thick plate (over 6 mm) Copper/Aluminum |
Development and production of prototype/Small-scale production | Jig manufacturing | Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Model manufacturing prototype mold |
Development and production of prototype/Small-scale production | Casting | Metal injection molding (MIM) Copper alloy |
Die manufacturing | Press die | Designing Part processing NC data creation 3D modeling Blanking die Forming die Fine blanking die Multi forming die Roll forming die Progressive die Transfer press die Single press die 60 - 300 t |
Die manufacturing | Forging die | Designing NC data creation Hot forging die Cold forging die Press forging die Warm forging die |
Die manufacturing | Casting die | Designing NC data creation 3D modeling Die-casting die |
Mass production | Metal press | Bending Blanking Forming Fine blanking Coining Iron Stainless steel Copper Brass Plated steel plate Warm forming press Beryllium copper Transfer press (80 - 200 t) |
Mass production | Mechanical processing | NC milling machining NC turning machining Rolling machining Micro-hole machining Iron Copper alloy Automatic screw machining High precision |
Mass production | Powder metallurgy | Metal |
Mass production | Sheet-metal processing | Precision sheet metal processing Sheet metal prototype manufacturing |
Mass production | Blank cutting | stainless Copper / aluminum |
Assembly/Inspection | Repair | Die repair |
Assembly/Inspection | Inspection | Metal press Casting |
Parts manufacturing | Machinery part | Connection parts manufacturing |
Parts manufacturing | Electrical part | Connector manufacturing Other electrical part manufacturing Switch manufacturing Power-supply device manufacturing |
Parts manufacturing | Spring | Copper alloy |
Parts manufacturing | Other parts | Lock manufacturing |
Auto parts manufacturing | Body part | Door lock Other body parts |
Product manufacturing | Construction and civil engineering machinery manufacturing | Pipe connection Interior and outer wall material manufacturing Lavatory products manufacturing Water supply and discharge system manufacturing |
Product manufacturing | Household commodity | Bath products manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing Cabinetmaking Interior manufacturing |
