Achieve Efficient Flow of People and Goods with the Medium-Sized Roll-Up Door "JT-2T". Manage the Work Environment More Smoothly with Rapid Opening and Closing and Safety Features.
The JT-2T is a medium-sized roll-up door designed to optimize the flow of people and goods within a factory. It accommodates a wide range of widths and heights, offering rapid opening and closing speeds along with high safety features. Suitable for various applications, it provides an efficient working environment with flexible control options.
Features
Versatile Applications: Accommodates a wide opening range (width 1000–4500mm, height 1000–4500mm) for various uses.
Rapid Opening and Closing: Maximizes work efficiency with an opening speed of 1.5m/s and a closing speed of 0.7m/s.
Safety Features: Equipped with an obstacle detection feature, it automatically reverses upon contact with an obstruction to ensure safety.
Emergency Evacuation Support: In emergencies, the curtain can be easily removed to support rapid evacuation.
Compact Design: High-quality design for effective space utilization.
Optional Features: Various options such as sheets, windows, switches, and sensors can be selected.
Specifications
Width: 1000–4500mm
Height: 1000–4500mm
Sheet Speed (Opening): 1.5m/s
Sheet Speed (Closing): 0.7m/s
Application: Indoor use
Applications
Flow Management of People and Goods: Smooth movement of people and goods within the factory, improving work efficiency.
Safe Passage: Ensures employee safety with obstacle detection and emergency evacuation features.
Efficient Space Utilization: Compact design allows for effective use of limited space.
The medium-sized roll-up door "JT-2T" is the ideal solution for optimizing the flow of people and goods within the factory, providing a safe and efficient working environment.
Company name | TOMAS ENGINEERING (THAILAND) CO., LTD. | EMIDAS Member Number | 95399 |
Country | Kingdom of Thailand | Street address |
Bangplee Samut Prakan Kingdom of Thailand |
Telephone number | +66-2-336-0711 | Fax number | +66-2-336-0574 |
Employees | 4,260,000 THB | Annual sales | |
Employees | 30 | Person in charge | Sales Department |
Type of manufacturing | Machine tools / Industrial machinery / Construction material | ||
Primary clients |
