Injection molding ( Mass production / Plastic ) |
Insert molding( Mass production / Plastic ) |
Below 60 t( Mass production / Plastic ) |
60 - 300 t( Mass production / Plastic ) |
LCP (liquid crystal polymer)( Mass production / Plastic ) |
PPS (polyphenylene sulfide)( Mass production / Plastic ) |
General-purpose material( Mass production / Plastic ) |
Engineering plastic( Mass production / Plastic ) |
PVC (polyvinyl chloride)( Mass production / Plastic ) |
Thin wall molding( Mass production / Plastic ) |
Company name | Yuwa Co., Ltd. | Website URL | http://www.yuwa-net.co.jp/ |
Street address |
Komoro Nagano Japan
[See map] |
Person in charge | eigyobu |
Telephone number | +81-267-25-8001 | Fax number | +81-267-25-8011 |
Capital | 44,000,000 JPY | Employees | 230 |
Annual sales | Unregister | EMIDAS Member Number | 94759 |
Type of manufacturing | Telecommunication equipment / Electronic parts / Medical equipment | ||
Main 3 products |
Primary clients |
PR message
Yuwa Co., Ltd. Deals with the production of connector parts, camera parts, LCD parts, fine precision molded parts for automobiles, and medical equipment, and the like, and is used in the ever-evolving smartphones and tablet devices.
Armed with advanced mold technology, we aim to expand globally in a wide range of fields.
We have confidence in manufacturing high-precision mold parts and producing high-quality mold parts at a constant temperature environment of 23°C ±0.5°C.
Most recent update:2024-10-24
Large | Medium | Small |
Designing | Mold designing | Injection molding die |
Development and production of prototype/Small-scale production | Machining | Tapping Machining/Handles small-scale production (order from 1 piece) Iron High rigid material Copper alloy Simultaneous 5-axis machining Handles microfabrication Handles microfabrication |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling 5-face/5-axis machining Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Form grinding Profile grinding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Prototype/Small-lot molding Small-lot/Injection molding Simplified/Molding prototype mold |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Plate machining Mold base machining NC data creation 3D modeling Injection molding die Insert molding die Below 60 t 60 - 300 t Injection molding die for microfabrication (5 mm or smaller) Core and cavity machining |
Mass production | Mechanical processing | Machining Tapping machining Wire machining Screw cutting machining Micro-hole machining Electrical discharge machining Iron Copper alloy High precision |
Mass production | Plastic | Insert molding PVC (polyvinyl chloride) General-purpose material PMMA (polymethyl methacrylate) Engineering plastic PPS (polyphenylene sulfide) LCP (liquid crystal polymer) Below 60 t 60 - 300 t Injection molding Thin wall molding |
Surface treatment | Heat treatment | Vacuum quenching Sub-zero treatment |
Assembly/Inspection | Inspection | Plastic |
