Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Chassis manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Thin (t0.5 or less) / Small sheet metal processing( Mass production / Sheet-metal processing ) |
Coating( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Powder coating( Surface treatment / Coating ) |
Silk screen printing( Surface treatment / Printing and others ) |
stainless( Mass production / Blank cutting ) |
Copper / aluminum( Mass production / Blank cutting ) |
Chemical conversion coating( Surface treatment / Plating/Chemical conversion treatment ) |
Company name | Tamagawa High Tech Co.,Ltd. | Website URL | https://www.tamagawa-hightech.co.jp/jp/ |
Street address |
Sannohe District Aomori Japan
[See map] |
Person in charge | 小笠原 秀悦 |
Telephone number | +81-178-60-1107 | Fax number | +81-178-60-1108 |
Capital | 70,000,000 JPY | Employees | 353 |
Annual sales | Unregister | EMIDAS Member Number | 94754 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Medical equipment | ||
Main 3 products |
PR message
Tamagawa High Tech's Sheet Metal Manufacturing Department (Fukuchi Factory No. 1) has a track record of producing a wide variety of products, including large enclosures for semiconductor manufacturing equipment, outdoor enclosures for roads and railways, medical equipment, defense-related equipment, and aircraft-related equipment. In addition, we have an integrated in-house production system from precision sheet metal to painting, assembly, and silk printing.
We can handle any precision sheet metal processing, from prototyping a small-lot-sized production to their mass production.
Feel free to contact us. (JIS Q 9100:2016 certified factory)
◆ Semiconductor manufacturing equipment
We specialize in manufacturing stainless steel doors and covers, painted doors and covers, optical parts, and anodized aluminum parts.
◆ Road/Railway
We are capable at outdoor enclosures. Waterproof test and thick film coating are available.
◆ Defense
We specialize in aluminum and stainless-steel waterproof structures. Waterproof test can be done in-house.
◆ Aircraft
We conduct one-off items such as ground support equipment and jigs. We have a lot of experience in vivid primary color painting.
Most recent update:2024-03-25
Large | Medium | Small |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Laser marking Turret punch punching Shirring Cutting process Laser and turret punch punching Laser processing (over 1.2m) Shirring (more than 1.2m) Connor Shah CO2 laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum |
Mass production | Sheet-metal processing | Pipe processing Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Bender processing (over 3.0m) Angle processing Pipe bender processing Deburring process Painting process Mirror surface material processing Hairline processing 3-roll machine Bender processing (flood control) Bender processing (servo) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Blank cutting | Laser marking Turret punch punching Shirring Cutting process Laser and turret punch punching Laser processing (over 1.2m) Shirring (more than 1.2m) Connor Shah CO2 laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum |
Surface treatment | Plating/Chemical conversion treatment | Chemical conversion coating Degreasing |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Electrostatic coating Flock coating Aqueous coating Airless spray coating Melamine coating Urethane coating Acrylic coating Lacquer coating Epoxy coating Heat insulation coating Heat-resistant coating Metal coating |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing Tool polishing Brush polishing Buffing Mirror polishing |
Surface treatment | Printing and others | Engraving Silk screen printing |
