Laser processing (over 1.2m)( Mass production / Blank cutting ) |
Bending process( Mass production / Sheet-metal processing ) |
Thick plate 6 mm or more( Mass production / Blank cutting ) |
Fiber laser processing( Mass production / Blank cutting ) |
Shirring (more than 1.2m)( Development and production of prototype/Small-scale production / Blank cutting ) |
Clean cut( Mass production / Blank cutting ) |
Shot blast( Surface treatment / Other surface treatment ) |
Company name |
株式会社 青鋼 (Seikou) |
Website URL | https://seikou-eastosaka.com/ |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 30 |
Annual sales | Unregister | EMIDAS Member Number | 94583 |
Type of manufacturing | Machine tools / Industrial machinery / Construction material |
Large | Medium | Small |
Material | Steel component distribution | Pickled steel plate Heavy plate Perforated metal Expanded metal Hot-rolled steel plate Cold-rolled steel plate Electroplated steel plate Hot-dipped steel plate Chequered plate Other steel plates and straps Shaped steel Flat steel plate Steel (round) bar |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Tapping |
Development and production of prototype/Small-scale production | Blank cutting | Laser marking Shirring Cutting process Laser processing (over 1.2m) Shirring (more than 1.2m) Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Precision cutting |
Mass production | Sheet-metal processing | Deburring process Bender processing (flood control) Bending process |
Mass production | Blank cutting | Laser marking Shirring Cutting process Laser processing (over 1.2m) Shirring (more than 1.2m) Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Precision cutting |
Surface treatment | Other surface treatment | Shot blast |
