Company name | THAI AICHI DENKI CO.,LTD. | Website URL | http://www.thaiaichi.co.th |
Street address |
Samur Prakan Samut Prakan Kingdom of Thailand
[See map] |
Person in charge | Mr Krittayot krittayot@thaiaichi.co.th |
Telephone number | +-27027161 | Fax number | +--2387-1346 |
Capital | 40,000,000 THB | Employees | 163 |
Annual sales | Unregister | EMIDAS Member Number | 94215 |
Main 3 products |
PR message
We products are manufactured with modern machines that cut, fold and drill according to designs with CNC machine. And company also products with laser machine to cut the steel plates which have some complicated shapes. The company is using White 2.3 millimeter iron sheet pre-coated with Zincphosphate, primed with paint base coat and surfaced with 2K paint, then heated to dry in the oven with the temperature ranging from 120 Celsius to keep the paint well stick to the board. The company also offers made-to-order switchboards as well as electricity system planning and switchboard design services by AutoCad Program according to customer’s need.
Latest information :
1. Received Mandatory TIS mark for new products of the RCCB/RCD & RCBO.
<Total 10 models>
2. Received Voluntary TIS mark for LC(Load Center) & CU(Consumer Unit)
Most recent update:2022-03-02
Large | Medium | Small |
Designing | Electrical planning | Electrical machinery and apparatus designing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining NC set press Chassis manufacturing Sheet metal protocol manufacturing Angle machining Deburring Coating Mirror surface machining Hair line machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing CO2 laser machining Thin plate (below 6 mm) Stainless steel |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding Arc welding |
Surface treatment | Coating | Powder coating Melamine coating |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Product manufacturing | Production property | Electrical machinery and apparatus manufacturing |
