A metal hot zone high-temperature vacuum furnace capable of stable operation in a vacuum environment at a maximum temperature of 2200°C and under an H2 atmosphere at 1800°C. Designed to resist deformation and wear in the hot zone, reducing maintenance costs, and achieving advanced heat treatment with fully automated operation.
The metal hot zone high-temperature vacuum furnace can operate stably at high temperatures up to 2200°C in a vacuum or 1800°C in an H2 atmosphere. This furnace adopts a hot zone design that is resistant to deformation and wear even under high temperatures, enabling high-quality heat treatment over long periods. With its program-controlled fully automatic operation feature, it significantly reduces the manual effort required while providing uniform heating throughout the product.
Features
High-temperature performance: Stable operation under up to 2200°C in a vacuum and 1800°C in an H2 atmosphere.
Low maintenance design: Excellent resistance to deformation and wear in the hot zone, reducing maintenance costs.
Uniform heating: Achieves uniform heating across the entire product due to a highly controlled temperature distribution.
Fully automatic operation: Easy and efficient fully automatic operation with program settings tailored to user requirements.
Specifications
Maximum temperature: 2200°C in a vacuum, 1800°C in an H2 atmosphere
Hot zone design: Durable design with measures against deformation and wear
Operating mode: Fully automatic operation by program
Applications: Wide range of heat treatment applications including high-temperature heating, carburizing, tempering, etc.
The metal hot zone high-temperature vacuum furnace is a culmination of leading technology developed to meet the needs for high-temperature heat treatment. Its high performance and efficiency make it a valuable investment for manufacturers requiring cutting-edge heat treatment solutions.
Company name | DOWA Thermotech (Thailand) Co., Ltd. | EMIDAS Member Number | 93649 |
Country | Kingdom of Thailand | Street address |
T.Tasit,A.Pluakdaeng Rayong Kingdom of Thailand |
Telephone number | Log in to display | Fax number | Log in to display |
Employees | 270,000,000 THB | Annual sales | 333,000,000 THB |
Employees | 101 | Person in charge | Shigehoro Kono |
Type of manufacturing | Transportation equipment |
