Industrial material
Thai Morishita
SELcon Shielded Stud is a press-fit product that is used to fix studs on the back side without creating unnecessary holes or protrusions when finishing the surface of decorative panels etc. beautifully. Easily installed using conventional press machines, this innovative stud provides high fixing strength without compromising surface aesthetics.
■ Features
- High punching force and rotational torque: The knurling part plastically deforms the mating plate material and is fixed around the reverse taper shank, achieving high punching force and rotational torque.
- Improved strength due to waveform displacement: The corrugated knurling section displaces the mating metal in a waveform, increasing the strength of the connection.
- Beautiful finish: The pressed surface after press-fitting is smooth, and additional post-processing is basically unnecessary.
■ Specifications
Installation method: Using a standard press machine, insert the guide part of the stud into the specified pilot hole, then apply pressure with the press.
Reliability: The fixing method by plastic deformation guarantees high punching force and rotational torque.
For more information, please download the PDF or feel free to contact us.
Company name | Thai Morishita Co., ltd. | EMIDAS Member Number | 93621 |
Country | Kingdom of Thailand | Street address |
Samutprkarn Samut Prakan Kingdom of Thailand |
Telephone number | +66-2-385-2157-60 | Fax number | +66-2-385-2161 |
Employees | Annual sales | ||
Employees | 20 | Person in charge | Kawamura (Mr.) |
