PR message
HBT Vietnam is a 100% Vietnamese invested enterprise with many years of experience in the field of manufacturing machines, molds, jigs, and assembly components.
Our engineers were educated in Japan and at top universities in Japan. Our workers are also graduates of famous domestic vocational schools. Our state-of-the-art equipment ensures product appearance and high precision to the satisfaction of our customers.
We specialize in processing jigs, auxiliary equipment to ensure high accuracy with professional warranty and customer care.
Materials: Steel
We specialize in processing all kinds of molds, jigs, assembly components… Diverse in materials, satisfying the needs of customers with beautiful appearance and high accuracy.
Materials: Steel, Stainless steel….
With modern machinery and a team of experienced engineers, HBT can provide complex products and details with low error rate, satisfying the needs of the most strict customers.
Materials: Aluminum, Steel, Stainless steel
Materials: Steel
We specialize in manufacturing pins, steel shafts, smooth shafts, graded shafts by high-tech CNC lathe with low error rate.
Tolerance: 0.02
Material: Steel
Quantity : according to the demand of customer
Tolerance : 0.01~0.1
We specialize in manufacturing valves, faucets, shafts, pistons, etc., by means of high-tech turning and milling with low error rate.
Tolerance: 0.02mm
Materials: aluminum
In addition to processing with a variety of materials, HBT also focuses on surface treatment such as anode, heat treatment, plating... towards the finished product in terms of quality, design, shape, eye catching.
Tolerance: 0.02mm
Materials: aluminum
NC milling machining( Mass production / Mechanical processing ) |
Company name | VIET NAM HBT PRECISE MECHANICAL JOINT STOCK COMPANY | Website URL | http://hbtvietnam.com.vn |
Street address |
Dong Anh Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | NGUYEN DUC TRUNG |
Telephone number | +84-24-3295-9829 | Fax number | +84-376038383 |
Capital | 500,000 $ | Employees | 80 |
Annual sales | 2,000,000 $ | EMIDAS Member Number | 93489 |
Type of manufacturing | Jigs and tools / Machine tools / Measuring machinery | ||
Main 3 products |
Primary clients |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing Automatic tool designing General-purpose jig designing |
Designing | Industrial equipment designing | Automatic machinery manufacturing Plant equipment designing Precision automatic machinery designing Industrial machinery designing Food industry machinery designing |
Material | Steel component distribution | Stainless steel pipe Electroplated steel plate Free-machining steel Steel (round) bar Other shaped steel bars Drawn steel pipe Cast-iron pipe |
Material | Specialized material distribution | Phosphor bronze Clad steel Molybdenum alloy Nickel chromium alloy Tin/Zinc based alloy |
Material | Nonferrous metal distribution | Steel (round) bar Steel bars and shapes Titanium Nickel Pipe material Others Aluminum extrusions |
Material | Plastic material distribution | PVC (polyvinyl chloride) |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Rolling Thread-cutting Profile milling Straightening Iron Stainless steel High rigid material Aluminum alloy Copper alloy Magnesium alloy Nickel alloy Machining (resin) Keyway milling Automatic lathe Bench lathe machining Milling (resin) Lathe machining (resin) Casting Handles microfabrication Handles microfabrication Honing Brass |
Development and production of prototype/Small-scale production | NC machining | NC milling NC lathe machining Boring milling NC facing NC vertical lathe Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Micro hole machining |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Corner shearing Thin plate (below 6 mm) Thick plate (over 6 mm) PI (polyimide) Other resins Precision cutting |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing prototype mold |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Complex turning machining Screw cutting machining Micro-hole machining Automatic screw machining High precision |
Parts manufacturing | Machinery part | Ring |
