弊社は工作機械部品一式・組付、航空機部品・試作、治工具・検査具、金型部品全般、自動車部品・試作など製造します。海外拠点の中国工場との連携で高品質・低価格・短納期など多様なニーズにも対応します。
Cylindrical grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Jig and tool manufacturing( Development and production of prototype/Small-scale production / Jig manufacturing ) |
Plane grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
NC milling ( Development and production of prototype/Small-scale production / NC machining ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
High rigid material( Development and production of prototype/Small-scale production / Machining ) |
Company name |
株式会社鈴木研磨 (Suzukikennma) |
Website URL | http://www.suzukikenma.com/ |
Street address |
Aichi Japan
[See map] |
Person in charge | - |
Capital | 12,000,000 JPY | Employees | 43 |
Annual sales | 1,852,000,000 JPY | EMIDAS Member Number | 92997 |
Type of manufacturing | Transportation equipment / Machine tools / Jigs and tools |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Gear hobber Thread-cutting Straightening Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Machining (resin) Sintered metal Keyway milling Automatic lathe Simultaneous 5-axis machining Milling (resin) Lathe machining (resin) Urethane Brass Diamond |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Sheet metal protocol manufacturing Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Laser marking |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Cylindrical grinding Profile grinding Internal grinding Centerless grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing |
