Industrial machinery
Anest Iwata
A booster pump is a device used to increase the pressure of liquids or gases in a piping system, allowing for more efficient transportation of these fluids to the desired location. Booster pumps are commonly used in water systems and air compression systems to enhance the existing pressure to a higher level.
High-Performance Booster for All Pressure Needs, with Easy Mobility
Features
The TLBS series is a booster compressor that achieves high mobility and easy inspection. Equipped with a large capacity tank and a standard secondary side filter, it boosts low-pressure air up to 3.0MPa. With an exposed mechanism, it offers high heat resistance and efficient compression with durability, thanks to the use of lubricating oil.
Specifications
The TLBS series includes two models: the TLBS55C30-S2 and TLBS75C30-S2, with electric motor outputs of 5.5kW and 7.5kW, respectively. The control pressure range is from 2.65MPa to 3.00MPa, with air discharge rates of 1550L/min and 1950L/min at 50Hz. These specifications ensure high compression performance and efficiency.
For more details, please download the PDF or feel free to contact us.
Company name | ANEST IWATA SOUTHEAST ASIA Co., Ltd. | EMIDAS Member Number | 92703 |
Country | Kingdom of Thailand | Street address |
Huaykwang Bangkok Kingdom of Thailand |
Telephone number | +66-2-643-2870 | Fax number | +66-2-643-2874 |
Employees | 90,000,000 THB | Annual sales | |
Employees | 45 | Person in charge | Mr. Noppasit Siripaskulwat |
