Industrial machinery
Anest Iwata
A vacuum pump is a device used to remove air and gases from a specific area or container to create a vacuum within that area.
Setting a New Standard in Vacuum Technology. Achieving an Oil-Free, Low-Vibration, and High-Efficiency Vacuum Environment with the ISP-90.
The ISP-90 dry vacuum pump, provided by Anest Iwata, is a high-efficiency and low-vibration vacuum generation device. By not using lubricating oil, it ensures a clean vacuum environment and supports a wide range of applications, including laboratory experiments, analytical equipment, and vacuum packaging machines.
Features
The pump's key feature is its ability to operate across a broad pressure range, from atmospheric pressure to its ultimate pressure. It is equipped with multi-voltage capabilities for global use and employs scroll technology for low vibration and noise. The design minimizes leaks and does not require cooling water or lubricating oil, significantly simplifying maintenance.
Specifications
The ISP-90 has a designed exhaust speed of 90 L/min at 50Hz and 108 L/min at 60Hz, with an ultimate pressure of less than 5Pa. The intake and exhaust port sizes are NW25 and NW16, respectively, and it uses an air-cooling system. Additionally, it operates within an ambient temperature range of 5°C to 40°C, with an approximate weight of 14kg and dimensions of 214×308×225mm.
As the demand for vacuum technology grows, the ISP-90 meets these needs by providing a clean and efficient vacuum environment, especially suited for fields requiring clean vacuums.
For more details, please download the PDF or feel free to contact us.
Company name | ANEST IWATA SOUTHEAST ASIA Co., Ltd. | EMIDAS Member Number | 92703 |
Country | Kingdom of Thailand | Street address |
Huaykwang Bangkok Kingdom of Thailand |
Telephone number | +66-2-643-2870 | Fax number | +66-2-643-2874 |
Employees | 90,000,000 THB | Annual sales | |
Employees | 45 | Person in charge | Mr. Noppasit Siripaskulwat |
