Industrial machinery
Anest Iwata
A vacuum pump is a device used to remove air and gases from a specific area or container to create a vacuum within that area.
Clean and Efficient Vacuum Creation, Achieved by ISP-50.
The ISP-50 from Anest Iwata is a dry scroll vacuum pump that can handle a wide range of pressure levels. It provides clean vacuum exhaust, operates efficiently with low vibration and noise, and is easy to maintain. With no backstreaming of lubricating oil, it performs excellently in various vacuum environments. Its applications include sputtering systems, evaporation equipment, and ion plating devices.
The ISP-50 dry vacuum pump is an innovative vacuum pump offered by Anest Iwata. Suitable for use in various industries, this pump creates a clean vacuum environment, enhancing the performance of equipment to its fullest potential.
Features
The most significant characteristics of this vacuum pump are its ability to operate efficiently with low vibration and noise. Additionally, the absence of lubricant backstreaming ensures a clean vacuum environment. Its easy maintenance ensures long-term, stable performance.
Specifications
The ISP-50 provides designed exhaust speeds for both 50Hz and 60Hz, with an extremely low attainable pressure. Its dimensions are 155mm x 317mm x 227mm, making it suitable for installation in various locations and compatible with a wide range of industrial equipment.
For more details, please download the PDF or feel free to contact us.
Company name | ANEST IWATA SOUTHEAST ASIA Co., Ltd. | EMIDAS Member Number | 92703 |
Country | Kingdom of Thailand | Street address |
Huaykwang Bangkok Kingdom of Thailand |
Telephone number | +66-2-643-2870 | Fax number | +66-2-643-2874 |
Employees | 90,000,000 THB | Annual sales | |
Employees | 45 | Person in charge | Mr. Noppasit Siripaskulwat |
