Industrial machinery
Anest Iwata
A vacuum exhaust system is designed to remove unwanted exhaust or gases from areas or equipment operating under vacuum conditions. This system uses vacuum pumps or similar devices to suction and expel gases or exhaust, maintaining the vacuum state and controlling the air quality in the working area.
Clean Exhaust and Energy Saving with the Vacuum Exhaust System
Anest Iwata's VMC-1000-GU2 is a vacuum exhaust system that boasts high exhaust volume and attainable pressure. By combining an oil-free scroll vacuum pump with a mechanical booster, it provides a clean and efficient exhaust solution to meet the diverse needs of the manufacturing industry.
Features
This system employs an oil-free scroll vacuum pump to enable clean exhaust. Additionally, it is designed for ease of use, allowing the simultaneous startup of the roughing pump and booster pump at the push of a button. The booster can be switched on/off as needed, realizing energy-saving operation when exhaust speed is unnecessary.
Specifications
The VMC-1000-GU2 is suitable for a wide range of applications including vacuum chucking, gas displacement, vacuum forming, and central vacuum exhaust. Its design is highly mobile, allowing installation in various locations. As a safety precaution, it is specified not to be used for exhausting toxic, explosive, or corrosive gases.
The VMC-1000-GU2 by Anest Iwata is introduced as a high-exhaust volume unit combined with a mechanical booster, utilizing an oil-free scroll vacuum pump for clean exhaust, with excellent operability and energy-saving effects. Its applications include vacuum chucking, gas replacement, vacuum forming, and central vacuum exhaust, with safety precautions also noted. Detailed specifications are provided.
For more details, please download the PDF or feel free to contact us.
Company name | ANEST IWATA SOUTHEAST ASIA Co., Ltd. | EMIDAS Member Number | 92703 |
Country | Kingdom of Thailand | Street address |
Huaykwang Bangkok Kingdom of Thailand |
Telephone number | +66-2-643-2870 | Fax number | +66-2-643-2874 |
Employees | 90,000,000 THB | Annual sales | |
Employees | 45 | Person in charge | Mr. Noppasit Siripaskulwat |
