マシニング、NC旋盤、汎用旋盤の職人です。
組立、量産品、実績物、その他ご要望あればお受けします。
Construction and civil engineering material manufacturing( Product manufacturing / Construction and civil engineering machinery manufacturing ) |
Machine tool manufacturing( Product manufacturing / Production property ) |
Other industrial machinery manufacturing( Product manufacturing / Production property ) |
Casting( Mass production / Mechanical processing ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
㈲大友機械製作所 (Ootomokikaiseisakujo) |
Website URL | http://ootomo-kikai.com/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | Employees | 6 | |
Annual sales | Unregister | EMIDAS Member Number | 92044 |
Type of manufacturing | Machine tools / Construction material / Industrial machinery |
Large | Medium | Small |
Designing | Test | Specimen processing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Deep hole drilling Gear hobber Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Keyway milling Milling (resin) Lathe machining (resin) Casting Urethane Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Mass production | Mechanical processing | Machining NC turning machining Tapping machining Complex turning machining Wire machining Stainless Aluminum alloy Copper alloy Titanium alloy Nickel alloy Molybdenum alloy Turning machining(plastic) Casting Titanium High precision |
Mass production | Sheet-metal processing | Can-making |
Surface treatment | Plating/Chemical conversion treatment | Other anti-rust treatments Hard chromium (rack) Black oxide finish Unichromate (white) |
Surface treatment | Heat treatment | Quenching Vacuum quenching High frequency quenching Salt bath soft nitriding (tufftriding) Nitridation |
Assembly/Inspection | Assembly | Construction component assembly Industrial machinery assembly |
Parts manufacturing | Machinery part | Shaft and roller manufacturing Mechanical parts |
Parts manufacturing | Bolt/Screw/Nut | Bolt manufacturing Nut manufacturing |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Food industry machinery manufacturing |
Product manufacturing | Plant equipment manufacturing | Hydro/thermal/electric/atomic power generation apparatus manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
Product manufacturing | Food industry machinery manufacturing | Other food industry machinery manufacturing |
Product manufacturing | Environmental equipment manufacturing | Waste water treatment system manufacturing |
