Copper( Mass production / Metal press ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Machining( Mass production / Mechanical processing ) |
Bending( Development and production of prototype/Small-scale production / Prototype processing ) |
Complex turning machining( Mass production / Mechanical processing ) |
High precision( Mass production / Mechanical processing ) |
Copper/Aluminum( Development and production of prototype/Small-scale production / Blank cutting ) |
Copper and brass products( Material / Nonferrous metal distribution ) |
Copper( Surface treatment / Plating/Chemical conversion treatment ) |
Company name | ISHIGAKI SHOUTEN Inc. | Website URL | https://ishigaki-st.com/ |
Street address |
Nagoya City Aichi Japan
[See map] |
Person in charge | Masahiro Ishigaki |
Telephone number | +81-52-793-3080 | Fax number | +81-52-793-1079 |
Capital | 10,000,000 JPY | Employees | 25 |
Annual sales | 500,000,000 JPY | EMIDAS Member Number | 91883 |
Type of manufacturing | Heavy electric machinery / Industrial machinery / Transportation equipment | ||
Main 3 products |
PR message
We, ISHIGAKI SHOUTEN Inc. are a company specializing in copper metal processing located in Nagoya City, Aichi Prefecture.
We have processing technology for cutting precision parts and high-precision sheet metal press.
We produce a wide variety of products in small quantities, even for 1 single item order.
We also handle express orders and short delivery times. Please feel free to contact us.
We handle a single item order of large transformers, control panels, switchboards, industrial equipment, high-speed railway parts, parts for solar power generation, wind power generation, electrode parts, small to large copper bus bar, copper bar processing, etc. We are also focusing on parts related to next-generation clean energy.
Utilizing our 70-year history of specialized copper metal processing technology, we also handle materials other than copper, such as copper alloys, aluminum, and brass.
◆Large press processing technology specializing in copper◆
We handle small to large processed products, including large copper bus bars up to 250 mm wide and 2500 mm long.
◆Precision processing technology specializing in copper◆
We handle complicated shapes using high-precision technology that suppresses heat variation with ultra-high-speed rotation.
◆Quality control◆
We implement quality control based on ISO9001.
◆ Acquired SBT Certification and Aichi Prefecture's Certification System ◆
As a rare achievement for a small or medium-sized company, we have obtained SBT certification.
We continuously engage in environmental conservation activities in collaboration with a national university, and have also received the Biodiversity Certification System from Aichi Prefecture.
As a company that deals with copper, a global resource, we are committed to understanding, learning about, and taking action on environmental issues.
Most recent update:2025-04-22
Large | Medium | Small |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar Copper and brass products |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Tapping Deep hole drilling Rolling Thread-cutting Straightening Machining/Handles small-scale production (order from 1 piece) Aluminum alloy Copper alloy Keyway milling Automatic lathe Simultaneous 5-axis machining Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Precision sheet metal machining Sheet metal protocol manufacturing Bending (over 3.0 m) Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Thick plate (over 6 mm) Copper/Aluminum Precision cutting |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Thread grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Prototype/Small-lot molding |
Development and production of prototype/Small-scale production | Casting | Copper alloy |
Mass production | Metal press | Bending Blanking Aluminum Copper Brass |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Rolling machining Screw cutting machining Aluminum alloy Copper alloy Automatic screw machining High precision High strength |
Mass production | Sheet-metal processing | NC set press Precision sheet metal processing Deburring process Bending process |
Mass production | Blank cutting | Shirring Cutting process |
Mass production | Welding / welding | CO2 welding TIG welding (argon welding) Arc welding |
Surface treatment | Plating/Chemical conversion treatment | Electroless copper (barrel) Tin (rack) Gold/Silver plating Electroless nickel (barrel) Electroless copper (rack) Electroless nickel (rack) Copper Brass Aluminum Hot-dip galvanizing (mid-size |
Surface treatment | Cleaning | Shower-type cleaning |
Surface treatment | Polishing/Lapping | Buffing |
Surface treatment | Heat treatment | Normalizing Annealing Quenching |
Surface treatment | Other surface treatment | Buffing |
Assembly/Inspection | Inspection | Metal press |
Assembly/Inspection | Side job processing | Manual labor |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing Bolt manufacturing Screw manufacturing |
