Aluminum die-casting ( Development and production of prototype/Small-scale production / Prototype processing ) |
5-face/5-axis machining( Development and production of prototype/Small-scale production / NC machining ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Machining (horizontal)( Development and production of prototype/Small-scale production / NC machining ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Sand casting( Development and production of prototype/Small-scale production / Casting ) |
Precision equipment assembly( Assembly/Inspection / Assembly ) |
Company name | Seiwa Co., Ltd | Website URL | http://www.seiwa-1.co.jp/ |
Street address |
Nishio-shi Aichi Japan
[See map] |
Person in charge | Masaki Osuka |
Telephone number | +81-563-56-2647 | Fax number | +81-563-57-4473 |
Capital | 25,000,000 JPY | Employees | 69 |
Annual sales | 935,000,000 JPY | EMIDAS Member Number | 91843 |
Type of manufacturing | Industrial machinery / Transportation equipment / Medical equipment | ||
Main 3 products |
PR message
[Reliable partner that makes prototypes and small-lot production into value]
Seiwa is a manufacturing company that focuses on precision cutting through various types of machining and NC lathe processing.
In particular, with our unique know-how based on our many years of experience, including the production of jigs, in the processing of complex shaped materials (castings) we provide satisfaction to our customers . We have strengths in the beauty of the finish, delivery time, and quality.
In the fields of automobiles and industrial robots, which are Japan's key industries, we specialize in small-lot, high-mix production, and focus on solving our customers' problems by providing high-quality prototype parts and small-lot mass-produced parts.
As another business, we also assemble precision equipment.
We handle a wide range of areas from procurement of various parts to assembly.
Most recent update:2025-03-31
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Thread-cutting Iron Aluminum alloy Magnesium alloy Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining 5-face/5-axis machining Five-face machining Boring milling NC facing Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing Plaster casting prototype Aluminum die-casting |
Development and production of prototype/Small-scale production | Casting | die-cast Gypsum casting Lost wax Gravity casting Sand casting cast iron Ductile cast iron Aluminum alloy 500g or less 500g-5kg 5kg or more |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Wire machining Gear cutting machining Screw cutting machining Iron Aluminum alloy Magnesium alloy Air chuck equipment Casting Ultra-thin High precision |
Mass production | Die-casting | 125 t or less 125 - 250 t Aluminum |
Mass production | Casting | Lost-wax Sand casting Cast-iron Aluminum alloy 500 g and below Over 500 g and less than 5 kg Plaster casting |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Zinc (rack) Alumite (anode oxidation) Electroless nickel (rack) Iron Aluminum Hard chromium (rack) Colored alumite Hard alumite |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
