PR message
Leading manufacturer and supplier in Vietnam:
1. Cast alloy
2. Space rig and steel structure
3. Aluminum alloy bar profile
4 Finishing aluminum Exported Japan EU, USA, Korea Thailand, UAE, Namibia, Saudi Arabia
Application:
Used to grind stone, clinker, cement, coal, ore ...
Common sizes:
Ball Ball Diameter: 15-120mm
Cylindrical ball with glass ruler: 10x10mm - 55x55mm
Specifications:
- Casting ball: Cr: 2%-30%
- Ball rolling, forging: C45, 50Mn, 60Mn,...
Main manufacturing, processing and manufacturing machinery equipment:
- Disamatic automatic mold making line – Denmark, capacity 6,000 tons / year
- Alphaset technology molding line – Omega, UK. Capacity 2,000 tons/ year.
- Automatic ball rolling line – China, Vietnam. Capacity 12,000 tons/ year.
- Continuous heat treatment line with a capacity of 30 tons/ day.
- CNC machining center and sworn machining equipment system.
Aluminum Profile Bar Group (since 2005)
- Aluminum extrusion profiles for construction: (DAA Itabelo, DAA Acarino, DAA Aluko): aluminum frame, door systems, flip doors, sliding doors, building walls,...
- Aluminum extrusion profiles for industries: conveyor frame, engine casing, heat dissipation plate, solar battery frame, medical equipment,....
This product is manufactured by modern technology lines and equipment such as extrusion equipment lines of UBE Japan - the world's leading manufacturer of presses and anodized lines, E.D. coatings, powder coating lines, Decoral wood grain film coating lines of Italy. CKDA owns CNC Machining Center to manufacture products that require high detail and accuracy. Also the entire extrusion service mold is designed and made by us.
DAA products are available in 53 provinces and cities nationwide and exported to the US, EU, Japan and South Korea markets,...
We can as EPC contractor including designing, fabricating, packing and installing.
Our products including:
- Material shed/storage (circular and length shape) for Cement plant, coal-fired power plant, mining,…
- The roffing systems for for sports complexes, stadiums, markets, supermarkets, factories...
- The roffing systems for tollgate stations, public constructions,…
Main facilities and equipments:
Our products are manufactured by the modern and compelete equipment from Germany according to European standards.
- Forging machine to produce joint ball, cone.
- CNC center for fabricating joint ball, cone, sleeve,
- Ball shot blasting machine
- Automatic welder, MIG/MAG
- Heat treatment system controlling is CNC
Application:
- Due to their high chemical strength, they are resistant to splashing in the environment at high temperatures and work in temperature and load conditions. The product is often used for the following cement production equipment:
+ Cage tube, flap valve,...
+ Heat exchange chains, nozzles, cold burners, cage tubes,....
+ Cold recording, recording plates,...
We specialize in supplying spare parts for dam machines serving in the cement, mining, ... such as: Hammer, hammer disc: manganese hammer, 2-layer hammer, alloy core hammer
We specialize in manufacturing and supplying:
Aluminum bar for industrial use:
- Conveyor frame, operation table
- Engine casing
- Radiator plate
- Lamppost
- Solar battery frame
- Medical equipment
- Clean room partition
- Toilet partition
- Curtain frame
- Bridge railing
- Aluminum ladder, portable awning
List of production, processing and manufacturing machinery
DAA aluminum products are manufactured on modern technology lines and equipment, with outstanding features, ensuring synchronization, modernity and high automation.
- Extrusion line 650 tons, 1350 tons, 1800 tons – UBE Japan, Korea
- A note-chemical line,
- Powder coating line,
- Decoral film line, Italy.
- CNC Machining Center
We emplement consulting, designing, producing and installing aluminum profiles suchs as doors, windows, glass curtain wall for hotels, resorts, apartments, buildings...
CKDA Windows are the piority choice of the leading construction corporations in Vietnam for high class projects such as Vingroup, Sungroup, FLC ...
This product is made by modern technology line such as:
- Extrusion line, 650T, 1350T, 1800T form Korea, UBE Japan - the world's leading press manufacture
- The anodizing line system
- The ED coating, sand blast, powder coating (up to 30years warantee),
- The wooden film covering line, Decoral from Italy.
- CNC center to machine products that require high precision and and complexity. We has the capacity to design and manufacture molds for extrusion machine.
- Single head, head-end Sawing Machine
- Vacuum glass lifter 1ton, Italy
- Pull bending machine, cutting, bending, punching machine
- The automatic aluminium section cutting machine, Fomindustrie, Turkey.
- CNC center
Cast Alloys Group (since 1989)
Includes ball crusher spare parts (balls, crushed ammunition, pads, partitions,..); vertical crusher /hammer machine parts, battering machines (roller casing, crushing table pads, hammers,...), furnace spare parts (burn plates, cold burners,..) and a variety of cast alloy spare parts for the cement, mining, coal-fired thermal power, ... and other industries.
Total domestic consumption of 8,000 tons of products / year and export more than 3,000 tons / year.
The main export markets are Netherlands, Italy, USA, Korea, Japan, Thailand, UAE, Australia, ...
Casting die designing( Designing / Mold designing ) |
Company name | DONG ANH LICOGI MECHANICAL JOINT STOCK COMPANY | Website URL | http://ckda.vn/ |
Street address |
Dong Anh Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | Duong Viet Hung |
Telephone number | +84-24-3883-3818 | Fax number | +84-24-3883-2718 |
Capital | 3,100,000,000,000 VND | Employees | 700 |
Annual sales | 10,000,000,000,000 VND | EMIDAS Member Number | 90203 |
Type of manufacturing | Jigs and tools / Machine tools / Construction material | ||
Main 3 products |
Primary clients |
Large | Medium | Small |
Designing | Mold designing | Forging die designing Casting die designing Extrusion molding die designing 3D modeling (press) 3D modeling (plastic) |
Designing | Product and part designing | Wooden product designing Model designing External design |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing Automatic tool designing General-purpose jig designing |
Designing | Data creation (3D scan) | 3D printer |
Material | Steel component distribution | Shaped stainless steel Steel (round) bar Cast-iron pipe Steel castings Other steel pipes |
Material | Specialized material distribution | Molybdenum alloy Nickel chromium alloy |
Material | Nonferrous metal distribution | Titanium Nickel Pipe material Aluminum extrusions |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Planer machining Plano miller machining Deep hole drilling Gear hobber Rolling Thread-cutting Profile milling Straightening Iron Aluminum alloy Titanium alloy Nickel alloy Molybdenum alloy Broaching Keyway milling Automatic lathe Bench lathe machining Simultaneous 5-axis machining Casting pipe manufacturing |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining Boring milling NC facing NC vertical lathe Combined lathe machining Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Deburring |
Development and production of prototype/Small-scale production | Grinding processing | NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Profile grinding Jig boring Jig grinding Cylindrical mirror grinding Internal grinding Centerless grinding Thread grinding NC internal grinding |
Die manufacturing | Forging die | Designing Manufacturing Hot forging die Cold forging die |
Die manufacturing | Casting die | Designing Die-casting part processing Die-casting die Shell moulding die |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Rolling machining Micro-hole machining Iron Stainless Aluminum alloy Titanium alloy Nickel alloy Molybdenum alloy Broaching machining Automatic screw machining Casting Honing machining |
Mass production | Forging | Press forging Drop hammer Iron Over 5 kg |
Mass production | Casting | Sand casting Cast-iron Cast steel Aluminum alloy 5 kg and over |
Mass production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Profile grinding Jig grinding Internal grinding Centerless grinding NC internal grinding |
Assembly/Inspection | Inspection | Casting |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Interior and outer wall material manufacturing |
Product manufacturing | Household commodity | Outdoor leisure product manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing Interior manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing |
