PCS-NISSIN is the BOI promoted joint venture company between P.C.S. Machine and NISSIN Precision Machine (Nissin Seiki) producing and supplying high precision DIE and metal stamping parts to the local and global manufacturers in the development of Thailand and worldwide fast growing industry.
PR message
PCS-NISSIN was established in 1994 with the initial registered capital 80 Million Baht or U.S. $ 3.2 Million. The factory is located in Nakhonratchasima (korat) , the major province in Northeastern of Thailand. The company provides customers with full services of stamping parts including from die design to die production, and also metal parts and assembly.
Company name | PCS-NISSIN CO., LTD. | Website URL | |
Street address |
273 M.2, T.Khamtaleso A.Khamtaleso Nakhon Ratchasima Kingdom of Thailand
[See map] |
Person in charge | 丸山 彰 |
Telephone number | +66-+66-4408-7972 | Fax number | +66-+66-4408-7972 |
Capital | 80,000,000 THB | Employees | 204 |
Annual sales | Unregister | EMIDAS Member Number | 89722 |
Type of manufacturing | Jigs and tools / Industrial machinery / Home electrical appliances | ||
Main 3 products |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing 3D modeling (press) |
Designing | Simulation | 3D modeling Cutting |
Material | Steel component distribution | Stainless steel Shaped stainless steel Perforated metal Flat steel plate |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) |
Development and production of prototype/Small-scale production | Grinding processing | NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding |
Die manufacturing | Press die | Designing Plate machining Blanking die Progressive die Press robot die |
Surface treatment | Polishing/Lapping | Tool polishing |
Assembly/Inspection | Assembly | Precision equipment assembly |
Assembly/Inspection | Inspection | Metal press |
