Part processing( Die manufacturing / Press die ) |
Lap polishing( Surface treatment / Lap polishing ) |
Lap mirror polishing( Surface treatment / Lap polishing ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
CVD (chemical vapor deposition)( Surface treatment / Other surface treatment ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Internal grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Company name |
株式会社 ビゼン (Bizenn) |
Website URL | http://www.bizen-net.com |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 30 |
Annual sales | 360,000,000 JPY | EMIDAS Member Number | 88873 |
Type of manufacturing | Jigs and tools / Machine tools / Electronic parts |
Large | Medium | Small |
Designing | Mold designing | Forging die designing General metal press die |
Designing | Simulation | Forging Press |
Material | Steel component distribution | Stainless steel Perforated metal Tool steel Spring steel Steel (round) bar |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Keyway milling Automatic lathe Bench lathe machining Handles microfabrication Handles microfabrication |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Mirror surface machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Profile grinding Cylindrical mirror grinding Internal grinding Centerless grinding NC internal grinding Rotary grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Die manufacturing | Press die | Manufacturing Part processing |
Die manufacturing | Plastic mold | Part processing |
Die manufacturing | Forging die | Forging die part processing |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Complex turning machining Wire machining Screw cutting machining Micro-hole machining Electrical discharge machining Iron Stainless Cemented carbide Molybdenum alloy Automatic screw machining Fine particle material accepted |
Mass production | Powder metallurgy | Metal High rigidity |
Surface treatment | Polishing/Lapping | Buffing |
Surface treatment | Lap polishing | Lap polishing Lap mirror polishing |
Surface treatment | Heat treatment | Annealing Vacuum annealing Quenching Vacuum quenching High frequency quenching Flame quenching Sub-zero treatment Carburized quenching Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Other physical vapor deposition methods (PVD) CVD (chemical vapor deposition) Coating Shot peening/WPC Buffing Sound blast DLC coating |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Stamp manufacturing |
