Colored alumite( Surface treatment / Plating/Chemical conversion treatment ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
General-purpose lathe machining( Development and production of prototype/Small-scale production / Machining ) |
Automatic machinery manufacturing( Designing / Industrial equipment designing ) |
Chassis prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Aluminum alloy( Mass production / Mechanical processing ) |
Stainless( Mass production / Mechanical processing ) |
Titanium( Mass production / Mechanical processing ) |
Bending( Development and production of prototype/Small-scale production / Prototype processing ) |
Company name | Toyo Rikagaku Kenkyusho Co., Ltd. | Website URL | https://www.toyorikagaku.com/ |
Street address |
Oto, Yahiko-mura, Nishikanbara-gun Niigata Japan
[See map] |
Person in charge | Yuta Higuchi |
Telephone number | +81-256-94-4835 | Fax number | +81-256-91-2017 |
Capital | 855,550,000 JPY | Employees | 296 |
Annual sales | Unregister | EMIDAS Member Number | 88798 |
Type of manufacturing | Telecommunication equipment / Electronic parts / Leisure goods | ||
Main 3 products |
PR message
Toyo Rikagaku Kenkyusho is a comprehensive manufacturer of metal processing that consistently produces various metal products from mold design to pressing, machining, welding, assembly, surface treatment, and finished products.
We have surface treatment facilities for stainless steel, titanium, and aluminum in our own factory, and the best feature is that we can perform "processing" and "surface treatment" in the same factory.
We can also handle assembly and sub-assembly at our own factory, and respond to customers' "collection needs".
By consolidating the content that multiple companies previously requested into one company, it is possible to reduce the management effort of the customer significantly.
Please entrust Toyo Rikagaku Kenkyusho with "package projects" including surface treatment and assembly.
【quality policy】
“We will devote ourselves to manufacturing that faces the direction of the customer.”
Satisfying the customer's required specifications, we quickly commercialize it at a reasonable cost.
In addition, we will continuously improve in order to respond to customer satisfaction.
Most recent update:2025-03-28
Large | Medium | Small |
Designing | Mold designing | Drawing metal press die designing General metal press die 3D modeling (press) |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Designing | Test | Specimen processing Destructive test Chemical analysis |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Precision automatic machinery designing |
Designing | Electrical planning | Electrical machinery and apparatus designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Magnesium alloy Titanium alloy Casting Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Deburring Coating Mirror surface machining Hair line machining Bending (hydraulic) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Shearing (longer than 121.2 m) Laser marking Microfabrication (laser machining ) Thin plate (below 6 mm) Stainless steel Copper/Aluminum Precision cutting |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Centerless grinding Magnetic Abrasive |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Plastic bonding Stud welding Other bonding methods Projection welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Aluminum die-casting prototype mold |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining 3D modeling Drawing die Bending die Blanking die Forming die Roll forming die Shaving die Transfer press die Single press die Press robot die Below 60 t 60 - 300 t |
Mass production | Metal press | Drawing Bending Blanking Forming Roll forming Shaving Coining Iron Stainless steel Aluminum Titanium Stainless steel material for spring Thickness Thickness Hydraulic counter pressure press Single press (below 80 t) Single press (80 - 200 t) |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Wire machining Screw cutting machining Electrical discharge machining Iron Stainless Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Titanium |
Mass production | Die-casting | Aluminum |
Mass production | Forging | Aluminum Others |
Mass production | Casting | Lost-wax Aluminum alloy |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Rhodium Nickel (rack) Tin (rack) Copper (rack) Gold/Silver plating Chromium (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (rack) Electrocasting Chemical conversion coating Trivalent Chromate (barrel plating) Aluminum Stainless steel Hard chromium (rack) Titanium Magnesium Degreasing Colored alumite Hard alumite Black chromate (black/green) |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Electrodeposition coating UV resistant coating Acrylic coating |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing Blade polishing Brush polishing Buffing Mirror polishing |
Surface treatment | Printing and others | Printing Silk screen printing Pad printing |
Surface treatment | Lap polishing | Lap polishing Lap mirror polishing |
Surface treatment | Heat treatment | Annealing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Buffing Shot blast Glass beads blast Ionized plating |
Assembly/Inspection | Inspection | Metal press |
Auto parts manufacturing | Body part | Other body parts |
Auto parts manufacturing | Interior part | Communication accessories Audio components |
Product manufacturing | Household commodity | rice-cooker and kettle manuacturing Outdoor leisure product manufacturing Plates and glasses |
