PR message
ETEK AUTOMATION SOLUTIONS JSC was established in 2006, is a member of Tan Phat Equipment Technology Joint Stock Company (Tan Phat Etek), operating in the following fields:
1. FAS (Factory Automation Solution): Automation solution for factories.
2. ETS (Education of Technology Solutinons): Training and vocational training equipment.
3. LAS (Life/ Utility Automation Solutions): Residential equipment.
4. WLS (Werehouse Logistics Solutions): Smart warehousing solution.
1. DESCRIPTION
- Application: Pick & place: Palletizing.
- Professions: CPG, F&B, Metal, Auto…
2. PRODUCTS
- Description: Wooden Pallets, Plastic pallet, Steel pallet
- Dimensions (max) (mm): 1219 x 1219 x 200 (option)
- Weight (max) (kg): 25
3. FUNTION
- Pallet dispensers automate the infeed of an empty pallet at regular intervals into the system.
4. BENEFIT
- Increased efficiency
- No manual pallet handling ∙ Reduced absence due To illness ∙ Reduced time used per pallet ∙
- Prevention of occupational injuries
5. SPECIFICATIONS
- Rated voltage (V) : 220
- Capacity (kW) : 0.55
- Pressure (MPa): 0,4 - 0,6
- Weight (Kg) : 600
- Dimensions (mm) : 2150 x 1340 x 2600
- Cycle time (s): 12
- Max layer: 10
1. DESCRIPTION
- Application: Pick & Place :Transfering, Palletizing.
- Professions: CPG, F&B, Metal, Auto, Construction..
2. PRODUCTS
- Description: Cartoon box
- Dimensions (max) (mm): 600 x 600 x 600*
- Weight (max) (kg): 80
3. FUNTION
- Pick, place, stack, or transport (goods) on a pallet
4. BENEFIT
5. SPECIFICATIONS
- Rated voltage (V): 380
- Capacity (kW): 6.5
- Overall Width (mm) (conveyor): 1400 ( 1200, 1000, 800,600 )
- Dimensions roller (mm): d = 90
- Max speed (m/s) (conveyer): 1
- Cycle time (s) (pick & place ): 10
1. DESCRIPTION
- Professions : 3C, plastic components..
2. PRODUCTION
- Description : Plastic tray
- Dimensions (max) (mm): 93 x 77 x 1
Weight (max) (kg): 0.1
3. FUNTION
- Automatic loading and unloading of plastic tray
- Using robot pick and place the product in the
trays
4. BENEFIT
- Increase productivity.
- Reduce manpower.
5. SPECIFICATIONS
- Rated voltage (V): 220
- Capacity (kW): 1
- Weight (Kg): 371
- Dimensions (mm): 2188 x 1492 x 1560
- Cycle time (s): 6
- Accuracy (mm): 0.3
6. PROCESS
- Transfering: Rodless cylinder (SMC,CKD…), Cylinder(CKD…)
- Pick and Place: Robot: Universel Robot, ABB, Omron….
- Loading & Stacking: Mechanical design : Lifting unit
- Positioning : Mechanical design
Speaker assemly line
1. DESCRIPTION
- Application: Screw, inspect
- Professions: 3C, plastic components...
2. FUNTION
- Automatically tighten screws and inspect power fusion.
3. SPECIFICATIONS
- Capacity (kW): 1
- Weight (Kg): 371
- Dimensions (mm): 2166 x 1937 x 1102
- Cycle time (s): 6
- Accuracy (mm): 0.4
1. DESCRIPTION
- Application: Assembly
2. FUNTION
- Plug the component (supplied as a tray) onto the PCB board
- Control information about the system.
3. SPECIFICATIONS
- Capacity (kW): 2
- Weight (Kg): 1720
- Dimensions (mm): 1500 x 1800 x 1650
- Cycle time (s): 6.0
- Accuracy (mm): 0.05
1. DESCRIPTION
- Application: Pick & place, Transfer, Assembly : (Speaker line)
2. FUNTION
- The assembly line consists of many stages: conveyor moves jig to the positions: receive products, glue dispenser, attached components to the products.
3. SPECIFICATIONS
- Capacity (kW): 2
- Weight (Kg): 1398
- Dimensions (mm): 9142 x 2705 x 2149
- Cycle time (s): 3
- Accuracy (mm): 0.15
- Spraying accuracy (mm): Accuracy of ±1%, >99% of the time
1. DESCRIPTION
2. FUNTION
- Automatic terminal block assembly
- Check the size after assembly.
- Functional test after assembly.
- Classify and product arrangements OK or NG.
3. SPECIFICATIONS
- Capacity (kW): 2
- Weight (Kg): 460
- Dimensions (mm): 2800 x 1570 x 1720
- Cycle time (s): 6.5
1. DESCRIPTION
2. FUNCTION
- Automatic assembly (Electronic divice have protective covers )
3. SPECIFICATIONS
- Rated voltage (V):220
- Capacity (kW): 2
- Weight (Kg): 470
- Dimensions (mm): 1350 x 1340 x 1600
- Cycle time (s): 16
Automatic machinery manufacturing( Designing / Industrial equipment designing ) |
Company name | ETEK AUTOMATION SOLUTIONS JSC | Website URL | |
Street address |
Thanh Tri Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | |
Telephone number | +84-985-131-868 | Fax number | +84-084-24-3685-7775 |
Capital | 400,000 $ | Employees | 200 |
Annual sales | 17,000,000 $ | EMIDAS Member Number | 88414 |
Type of manufacturing | Jigs and tools / Machine tools | ||
Main 3 products |
Large | Medium | Small |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Precision automatic machinery designing Energy-saving machinery designing |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing Large-size plant apparatus manufacturing |
