Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Aluminum die-casting ( Development and production of prototype/Small-scale production / Prototype processing ) |
Sand casting die( Die manufacturing / Casting die ) |
Sand casting ( Mass production / Casting ) |
Transmission( Auto parts manufacturing / Drive system part ) |
Radiator parts( Auto parts manufacturing / Engine ) |
Company name | PROTO Co., Ltd. | Website URL | |
Street address |
Kyouto-fu Kuseto Kuseyama-chou Nomura-mati Kyoto Japan
[See map] |
Person in charge | Yoshinari Hasegawa |
Telephone number | +81-774-62-0004 | Fax number | +81-774-62-0009 |
Capital | 10,000,000 JPY | Employees | 48 |
Annual sales | Unregister | EMIDAS Member Number | 87612 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Transportation equipment | ||
Main 3 products |
PR message
Production process for aluminum casting.Proto Co., Ltd., specializes in manufacturing a variety of different types of industrial machine parts. We not only accept small lot prototype manufacturing, but also can do and support assembling as well as mass production of the final product. We are proud to offer short lead time and precision. Whenever we manufacture products, we always remind ourselves to be highly precise and to have a short lead time.To implement such an idea, we have installed state-of-the-art equipment which can do rapid prototyping and manufacturing of the model exactly as designed while also researching for better technology. A time-consuming job is beautiful. As it is a characteristic of the prototype manufacturing field,a variety of samples is made in small lots. Each prototype will have its own unique drawings and as it is made of a variety of raw materials it results in being very time-consuming. Nevertheless,we love and enjoy time-consuming prototype manufacturing.
Most recent update:2025-03-03
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Thread-cutting Machining/Handles small-scale production (order from 1 piece) Aluminum alloy Simultaneous 5-axis machining Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Powder sintering Aluminum die-casting |
Development and production of prototype/Small-scale production | Casting | Sand casting cast iron Ductile cast iron Cast steel Aluminum alloy 500g-5kg |
Die manufacturing | Casting die | Sand casting die Wooden model |
Mass production | Mechanical processing | Machining NC turning machining Five-face/axes machining Iron Stainless Aluminum alloy Casting High precision |
Mass production | Casting | Sand casting Aluminum alloy 500 g and below Over 500 g and less than 5 kg 5 kg and over |
Surface treatment | Plating/Chemical conversion treatment | Alumite (anode oxidation) |
Surface treatment | Heat treatment | Annealing Quenching Solution heat treatment |
Parts manufacturing | Machinery part | Valve manufacturing |
Auto parts manufacturing | Drive system part | Transmission Caliper Brake parts |
Auto parts manufacturing | Engine | Cooling system Radiator parts |
Product manufacturing | Medical equipment manufacturing | Dental products |
