PR message
Established in 1981, over 30 years of establishment and development, from a small mechanical base, Manh Quang Mechanical Co., Ltd. has become a large leading company in the production of motorcycle parts in Vietnam.
Manh Quang Co., Ltd. manufactures various chains and sprockets for vehicles. Our products have been used by retailers and OEMs for many years.
We can produce gears with a maximum diameter of 1200 mm and a thickness of 250 mm and Modul with a maximum thickness of 150 mm using the latest dedicated equipment.
We specializes in the manufacture of various high-precision motorcycle parts.
Company name | MANH QUANG CO.,LTD | Website URL | http://manhquang.vn/ |
Street address |
Hai Ba Trung Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | Nguyen Kim Loan |
Telephone number | Log in to display | Fax number | Log in to display |
Capital | 94,500,000,000 VND | Employees | 250 |
Annual sales | 210,000,000,000 VND | EMIDAS Member Number | 86036 |
Main 3 products |
Large | Medium | Small |
Designing | Mold designing | NC data creation (press) |
Designing | Product and part designing | Gear designing |
Development and production of prototype/Small-scale production | NC machining | NC milling NC lathe machining NC facing Combined lathe machining Handles 2.5-dimensional processing |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) Robot welding Fiber welding |
Die manufacturing | Press die | Designing Bending die 60 - 300 t |
Mass production | Metal press | Combined press-joining |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Gear cutting machining Screw cutting machining Iron Stainless Aluminum alloy Automatic screw machining |
Surface treatment | Plating/Chemical conversion treatment | Zinc (barrel) |
Surface treatment | Heat treatment | Quenching High frequency quenching |
Surface treatment | Other surface treatment | Shot blast |
Parts manufacturing | Machinery part | Gear manufacturing Shaft and roller manufacturing |
Auto parts manufacturing | Drive system part | Brake parts |
