With more than 50 years of experience, we are proud to be Vietnam's leading enterprise in the field of supporting industries. Currently, we are a long-term partner with multinational corporations such as Honda, Toyota, LG, Piaggio, Panasonic, Canon, SYM, Foxconn, Ariston, Sony, Daikin, Toyota Boshoku, Toto, Brother... and large domestic enterprises such as Vinfast, Hoa Phat, Thaco,...
PR message
Hanoi Plastics can produce a variety of high-tech plastic products, supplying to industrial and civil sectors. The main products of Hanoi Plastics are electric and electronic components, motorbike and automotive spare parts, air conditioning components, printer–fax components, household electronics, etc., supplied to global brands.
Machining speed is fast and accurate
Can handle bulk orders
Delivery on time
Delivery on time
We provide high quality plastic boxes, large quantities, on-time delivery
Our products belong to the line of industrial plastic containers, convenient to use, simple in design, bringing optimal efficiency to industrial production units, shops, factories, supermarkets, and households.
Plastic crates have a geometric design with ribbed lines to enhance product stability.
With PP plastic material with mechanical properties, shiny surface, easy to clean, solid plastic containers are safe for industrial use and meet RoSH Test standards.
We manufacture and distribute many products: industrial plastic containers, industrial plastic waves, plastic trays...
Providing high-quality plastic pallets with large quantities and on-time delivery
Specifications:
- Outer Dimensions: 1,100×1,100x120mm
- Material: PP
- Weight: 8kg
- Number of lifting directions: 4
- Dynamic load: 1500kg
- Static Load: 4000kg
Company name | Hanoi Plastics Joint Stock Company (HPC) | Website URL | https://www.hanoiplastics.com.vn/ |
Street address |
Long Bien Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | Hieu |
Telephone number | Log in to display | Fax number | Log in to display |
Capital | 50,000,000 $ | Employees | 2000 |
Annual sales | 80,000,000 $ | EMIDAS Member Number | 85340 |
Type of manufacturing | Home electrical appliances / Telecommunication equipment / Electronic parts | ||
Main 3 products |
Primary clients |
Large | Medium | Small |
Die manufacturing | Plastic mold | Designing Manufacturing Plate machining Mold base machining |
Die manufacturing | Rubber mold | Designing Rubber mold part processing Part processing Packing-related products Home electrical appliances |
Mass production | Plastic | Thermoset resin Pipe extrusion molding Tube extrusion molding Special shape extrusion molding Owns dies of commercially availalable size |
