PR message
We Specialize in Designing, Manufacturing and Receiving Mechanical Processing in 5 Fields:
- Tank head
- Air Received Tank
- Gas Tank, Oil Storage Tank
- Boiler
- Processing According to Drawings
- The products of ball cap and ball cap push are designed and manufactured according to ASME standards (E2:1).
- The material used to make the ball cap has a clear origin, ensuring the correct thickness of the cap blank.
- Modern plasma and CNC automatic cutting machines ensure that the blank used to make the ball cap has standard size, without bevels or diagonals due to manual cutting;
- 1500-ton hydraulic press, pressing blanks up to 8000mm in diameter;
- Ball cap rolling machine with different sizes and angles to meet all customer requirements.
Currently, with new manufacturing technology, Dong Anh Pressure Equipment is equipped with additional auxiliary systems such as level 1 dry dust removal, 3-level wet dust removal to ensure the system meets environmental standards according to QCVN19:2009 BTNMT and to improve efficiency, easy and safe operation.
Pressure vessels are designed and calculated using SOFTWARE installed according to ASME - Section VIII - Divison 1 US standards and TCVN 8366
- Manufactured on modern machinery systems to achieve depth E2:1. Achieve even roundness, perfect cutting angle.
- 100% automatic welding. High standard welding materials. Welders have 5G 6G certificates. Gouting
100% ultrasonic. 100% hydraulic test. State-inspected vessels.
Company name | DONG ANH PRESSURE EQUIPMENT JOINT STOCK COMPANY | Website URL | https://www.noihoidonganh.com |
Street address |
Ha Noi Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | CHE THU HUONG |
Telephone number | +84-9-7920-8509 | Fax number | Log in to display |
Capital | 1,000,000 JPY | Employees | 50 |
Annual sales | 5,000,000 $ | EMIDAS Member Number | 85300 |
Type of manufacturing | Jigs and tools | ||
Main 3 products |
Large | Medium | Small |
Designing | Product and part designing | Pressure container designing |
Material | Steel component distribution | Shaped stainless steel Hot-rolled steel plate Cast-iron pipe |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Can manufacturing (over 5 m) |
Surface treatment | Coating | Urethane coating Epoxy coating Heat-resistant coating Metal coating |
Surface treatment | Other surface treatment | Shot blast Sound blast |
Parts manufacturing | Machinery part | Pressure container manufacturing |
