Most recent update: 2024-06-26
PR message
Our company JAT operates in the industry of manufacturing auto parts, motorcycles, mechanical products with the motto: Stable quality - Fast delivery time - Low cost
we improve continuously, integrate the advanced science and technology, ensure each part is the perfect product to meet technical standards, satisfy customer' requirement.
part is the perfect product to meet technical standards, satisfy customer's requirement
Company name | Jat Autoparts And Industrial Equipments Production Joint Stock Company | Website URL | http://jat-autopart.com/ |
Street address |
Que Vo District Bac Ninh Socialist Republic of Vietnam
[See map] |
Person in charge | NhatDuyTran |
Telephone number | Log in to display | Fax number | Log in to display |
Capital | 400,000 $ | Employees | 350 |
Annual sales | 13,000,000 $ | EMIDAS Member Number | 85096 |
Type of manufacturing | Jigs and tools | ||
Main 3 products |
Large | Medium | Small |
Material | Steel component distribution | Heavy plate Stainless steel Perforated metal Stainless steel pipe Hot-rolled steel plate Electroplated steel plate Shaped steel Steel (round) bar Rectangular steel pipe Steel forgings Other steel pipes Garubariumu steel |
Development and production of prototype/Small-scale production | NC machining | NC milling NC lathe machining Boring milling NC facing NC vertical lathe Machining (horizontal) |
Die manufacturing | Press die | Designing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Forming die Fine blanking die Roll forming die Progressive die Transfer press die Single press die 60 - 300 t |
Die manufacturing | Plastic mold | Plate machining Mold base machining NC data creation |
Mass production | Metal press | Bending Forming Fine blanking Roll forming Transfer press (below 80 t) Iron Aluminum Copper Plated steel plate Thickness φ0.6mm - φ9.0mm Transfer press (80 - 200 t) |
Mass production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Jig grinding Internal grinding NC internal grinding |
Surface treatment | Heat treatment | Annealing Vacuum annealing Quenching Vacuum quenching Carburized quenching |
Assembly/Inspection | Assembly | Office equipment assembly Auto parts assembly |
Assembly/Inspection | Repair | Precision equipment repair Die repair |
Auto parts manufacturing | Drive system part | Transmission Brake parts |
Auto parts manufacturing | Engine | Cooling system |
Product manufacturing | Furniture/Interior | Cabinetmaking Interior manufacturing |
