Machines that create precision products. The parts themselves are the micro world. Kito Seiki Seisakusho meets the needs of the most important parts in high-precision, highly difficult parts processing, such as prototype parts with ultra-high variety and extremely low production volume, machine tool parts, and aerospace parts.
5-face/5-axis machining( Development and production of prototype/Small-scale production / NC machining ) |
Cylindrical grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Machine tool manufacturing( Product manufacturing / Production property ) |
Vacuum equipment manufacturing( Product manufacturing / Production property ) |
Thread grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Titanium( Development and production of prototype/Small-scale production / Machining ) |
Company name | Kito Seiki Seisakusho Co., Ltd | Website URL | https://www.kitouseiki.co.jp/ |
Street address |
Toyota City Aichi Japan
[See map] |
Person in charge | |
Telephone number | +81-565-52-3757 | Fax number | +81-565-52-8567 |
Capital | 20,000,000 JPY | Employees | 50 |
Annual sales | Unregister | EMIDAS Member Number | 83448 |
Type of manufacturing | Jigs and tools / Machine tools / Transportation equipment | ||
Main 3 products |
PR message
Our strengths
■National Skills Certification
To fulfill the high needs of our clients, all of our staff are continually sharpening their knowledge and abilities with the goal of achieving National abilities Certification Grade 1.
Currently, our craftsmen holding various certifications.
■Repair of rotary tools (milling units)
Our company has been creating rotary tools for many years, with a peak output of 2,000 units per year. In 2016, we established a "rotary tool repair service business" based on our strong technological skills. Our repair service's most notable characteristic is its ability to fix all manufacturers' items with the same accuracy as new ones. As of March 2024, we have fixed over 6,000 devices.
In addition, starting in 2024, we offer spindle unit repair services.
Advantages of rotating tool repair are significant cost savings (up to 80%), restore accuracy to match newer products and help achieve SDGs.
■Cutting Technology
Please leave round items with high accuracy and are difficult to produce like spindles and shafts to us. We have developed and supplied several spindles and shafts that are essential in vehicles, machine tools, industrial machinery etc. We can produce crankshafts with 0.002 mm roundness & concentricity, 0.8S surface roughness, control shafts with 0.5 mm thin-walled polished parts on one side, and eccentric shafts with shifted central axis. We are also capable of shaping such as gear cutting, splines, thread cutting, and key grooves.
Processing examples include spindles for machine tools, crankshafts for automotive products, and shafts for industrial machines.
■Internal grinding
This method involves grinding the inside diameter of cylindrical parts. It can handle a range of Φ6mm to Φ260mm. It also enables internal grinding at any taper angle, even 30°. *Depending on size.
High-precision internal grinding technique delivers roundness, coaxiality, cylindricity, and runout accuracy from the center of 0.001mm and up.
Surface roughness Ra.0.1μm and up.
■Cylindrical grinding
This process involves grinding the outside diameter of cylindrical parts. We can handle diameters ranging from Φ2mm to Φ350mm. We can handle any taper angles, even the 30° angle. *Depending on size
We can grind shafts as long as 1000mm. The dimensional tolerance of 1000mm is ±0.002mm. We also have a CNC cylindrical grinding equipment for mass manufacturing, which can handle everything from single items to large quantities. Geometric tolerances for roundness, coaxiality, runout accuracy and end face squareness are 0.001mm and up, surface roughness Ra is 0.1μm and up.
■Flatness grinding
Flatness, parallelism, squareness, and other features can be modified starting at 0.001 mm.
We can process sizes ranging from 10mm x 10mm to about 400mm x 800mm.
We have a track record of obtaining a symmetry degree of 0.005 when polishing the groove forms of round products, as well as flatness and parallelism with 0.01 mm accuracy when grinding extremely thin plates of stainless steel SUS304 (t=0.8 mm).
■Integrated Production System
We handle each process including processing, polishing, surface treatment, assembling, and inspection.
Our integrated production system solves the concerns of stable quality, short delivery times, and cost saving.
We have a network of over 100 partner manufacturers that support us for particular processes, surface treatments, heat treatments, etc.
■Quality Assurance System
In accordance with customer requests, we attach measurement data from a coordinate measuring machine when delivering products. We can also give comparable assistance with various measurement devices, such as roundness, form, and surface roughness gauges.
We can fulfill client demands by advance preparation measuring spots and methods.
(Contact information)
Kito Seiki Seisakusho Co., Ltd.
Sales Management Department: Naruse
Assembly Division (rotary tool repair related): Nakamura
TEL +81-565-52-3757 FAX +81-565-52-8567
URL http://www.kitouseiki.co.jp
Most recent update:2025-02-28
Large | Medium | Small |
Designing | Product and part designing | Measurement/testing device designing |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing General-purpose jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Deep hole drilling Gear hobber Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Machining (resin) Broaching Keyway milling Simultaneous 5-axis machining Milling (resin) Lathe machining (resin) Casting Honing Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining 5-face/5-axis machining Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Sheet metal protocol manufacturing Angle machining Coating 3D pipe machining |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) CO2 laser machining Laser marking Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic Precision cutting 3D laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC cylindrical grinding Plane grinding Cylindrical grinding Profile grinding Jig grinding Internal grinding Centerless grinding Thread grinding Gear grinding NC internal grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Arc welding Brazing Friction welding YAG laser machining |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Small-size prototype manufacturing Aluminum die-casting |
Mass production | Metal press | Bending Blanking Iron Stainless steel Aluminum Thickness Combined press-joining |
Mass production | Rubber | Rubber product prototype manufacturing Compression molding Blanking Silicon rubber Urethane rubber Packing-related products |
Mass production | Forging | Hot forging Cold forging Iron Aluminum Brass 500 g - 5 kg Over 5 kg Free forging |
Mass production | Casting | Lost-wax Sand casting Cast-iron Ductile cast iron Cast steel Aluminum alloy 500 g and below Over 500 g and less than 5 kg 5 kg and over |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Gold/Silver plating Chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Electroless nickel (barrel) Electroless nickel (rack) Trivalent Chromate (barrel plating) Iron Copper Aluminum Stainless steel Hard chromium (rack) Black oxide finish Colored alumite Hard alumite Unichromate (white) |
Surface treatment | Coating | Epoxy coating Heat-resistant coating Metal coating |
Surface treatment | Polishing/Lapping | Electropolishing Tool polishing Blade polishing Buffing |
Surface treatment | Lap polishing | Lap polishing |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Salt bath quenching Vacuum quenching High frequency quenching Sub-zero treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Other physical vapor deposition methods (PVD) CVD (chemical vapor deposition) Coating Spraying Teflon coating Buffing Shot blast |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly Industrial machinery assembly |
Assembly/Inspection | Repair | Precision equipment repair Industrial machinery repair |
Assembly/Inspection | Inspection | Rubber Measuring |
Parts manufacturing | Machinery part | Gear manufacturing Valve manufacturing Bearing manufacturing Vacuum components manufacturing Crank shaft manufacturing Shaft and roller manufacturing |
Parts manufacturing | Spring | Compression coil spring Leaf spring Torsion spring Carbon steel Stainless steel Copper alloy Diameter Diameter |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing Measurement/testing devices manufacturing Vacuum equipment manufacturing Food industry machinery manufacturing Industrial robot manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing |
