Semiconductor manufacturing equipment manufacturing( Product manufacturing / Production property ) |
Energy-saving equipment/Automatic instrument manufacturing( Product manufacturing / Production property ) |
Industrial machinery designing( Designing / Industrial equipment designing ) |
Energy-saving machinery designing( Designing / Industrial equipment designing ) |
Industrial machinery assembly( Assembly/Inspection / Assembly ) |
Precision equipment assembly( Assembly/Inspection / Assembly ) |
General jig designing( Designing / Jig and tool designing ) |
Jig and tool manufacturing( Development and production of prototype/Small-scale production / Jig manufacturing ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Company name | FUJISEN Technical Industry Co., LTD. | Website URL | |
Street address |
Ashikaga City Tochigi Japan
[See map] |
Person in charge | FUJISEN Techncail Industray Co.,Ltd. |
Telephone number | Log in to display | Fax number | Log in to display |
Capital | 90,000,000 JPY | Employees | 80 |
Annual sales | Unregister | EMIDAS Member Number | 82076 |
Type of manufacturing | Jigs and tools / Measuring machinery | ||
Main 3 products |
PR message
"At our company, we will provide you:
◎ Low price + high quality + super-express correspond. We will meet the needs of our customers 24 hours a day, 365 days a year.
◎ Our specialty are high-precision, high-speed machining cutting and sheet metal processing
◎ We can also provide total solutions such as design, development and assembly
First, you may compare our quotation with other company."
Most recent update:2024-10-10
Large | Medium | Small |
Designing | Product and part designing | Measurement/testing device designing |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Industrial machinery designing Energy-saving machinery designing |
Designing | Electrical planning | Electrical machinery and apparatus designing PCB designing Other electronic part designing Eletronic circuit designing PLD/FPGA designing |
Designing | Simulation | 3D modeling Cutting Structure |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Thread-cutting Profile milling Straightening Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Keyway milling Automatic lathe Simultaneous 5-axis machining Handles microfabrication Titanium Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Boring milling Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Deburring Coating Mirror surface machining 3-roll bending Bending (hydraulic) Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Laser and turret punch press processing Corner shearing Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Precision cutting Fiber laser processing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding Capacitator spot welding Other bonding methods |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Assembly/Inspection | Assembly | Precision equipment assembly Office equipment assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Metal press Plastic Rubber Spring Bolt/Screw/Nut Measuring |
Parts manufacturing | Machinery part | Vacuum components manufacturing Optical parts manufacturing Measurement devices manufacturing |
Parts manufacturing | Electrical part | Harness processing Cable manufacturing |
Product manufacturing | Production property | Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing Measurement/testing devices manufacturing Optical products manufacturing Freezer equipment manufacturing Vacuum equipment manufacturing Food industry machinery manufacturing Chemical industry machinery and equipment manufacturing Information equipment manufacturing Environmental equipment manufacturing Semiconductor manufacturing equipment manufacturing LCD manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Others | Transportation equipment manufacturing Telecommunication equipment manufacturing |
